R56 VANOS reset adaptations
Old Aug 2, 2021 | 09:57 AM
KeelynnN18's Avatar
KeelynnN18
I am looking for a tool that will reset Vanos adaptions in a 2011 MCS N18. Noone seems 100% sure
ECS says this one should
https://www.ecstuning.com/b-schwaben...CABEgIfqfD_BwE
but the Foxwell version says it wont.
Is there any tool/program under 300 USD that will do this? Im into this car for over 2000 bucks this year just in parts and am running low on funds
I am a bit iffy on trying the power latch procedure. thanks for the help. Keelynn
Old Aug 2, 2021 | 10:16 AM
KeelynnN18's Avatar
KeelynnN18
Carly said it wont do this
Bimmercode said no
Bimmer tool said no
Foxwell 510 said no
Autophix 7910 said no
I did see
Amazon Amazon
for 85 bucks on amazon that the seller said would work. Can anyone confirm this?
Old Aug 2, 2021 | 11:06 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Are you replacing your VANOS solenoids? If so, I replaced both mine, and never had to reset anything.... Maybe they WON'T reset adaptation because you don't need to?
Old Aug 2, 2021 | 12:23 PM
KeelynnN18's Avatar
KeelynnN18
I replaced both before I found out the plastic guide rail was broken while changing a leaking oil pan gasket. Had to change the timing chain and rails and its recommended to reset vanos adaptions after that job.
sarge21rvb
Oct 14, 2017 12:18 PM
coopspeed
Aug 10, 2016 09:55 AM
Madwick
Apr 9, 2014 12:40 PM
