R56 Clunking sound when going over bumps on road
Old Apr 24, 2021 | 03:32 PM
Papote's Avatar
Papote
When I go over bumps the passenger side clunks pretty bad. I push on the car from each side on the front and it is not bouncy.
I noticed a while back some clunking sound when turning my steering wheel from side to side.
I lifted each side of the front tires and found some play. I only hear the clunks from the passenger side, but the driver side also has some play.
I have a 2008 MCS with 72K miles.
What could this be?
Should I be very worried?
Can I make this worse and more expensive if I continue to drive like this?
Oddly enough, the steering feels quite fine.
Old Apr 24, 2021 | 06:44 PM
NeonLed's Avatar
NeonLed
Mine does the same thing like in the first video. I think its the control arm bushings but I could be wrong.
Old Apr 25, 2021 | 09:59 AM
Gubi's Avatar
Gubi
Whoa, that's pretty bad play! Yeah, check the lower control arm bushings first: they don't last very long.
With that much wobble it should be incredibly obvious if they're bad.
Old Apr 25, 2021 | 10:03 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
You should not have ANY side to side play in the front wheels. Based on those videos, I would check tie rod ends. I don't think a rear control arm bushing would move that easy.
Old Apr 25, 2021 | 10:05 AM
Papote's Avatar
Papote
You'd think the car would go all over the place in terms of steering, but it handles just fine, just the clunking on the right front side. I was surprised that both front sides wheels wobble so much. It does require a bit if force to make it wobble as shown on the video. I tried jiggling from top to bottom, but it doesn't budge, so I guess that's good.
How would I go about testing for bushings or tie rod ends? Not really sure where to start.
Old Apr 25, 2021 | 02:19 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
For the tie rods, jack the car up, take the wheel off, and the tie rod is right there. Wiggle the knuckle, like you did in the video above, and it should be apparent where the movement is coming from.
Old Sep 28, 2021 | 07:07 PM
Papote's Avatar
Papote
Aperrently, it is the rack and pinion.
Old Sep 29, 2021 | 03:47 PM
A383Wing's Avatar
A383Wing
are you sure that it's not a bad strut?
Bryan
Old Sep 29, 2021 | 04:06 PM
Papote's Avatar
Papote
Bryan
Tried to replace the upper and lower ball joints, but there is play in the rack.
Old Sep 29, 2021 | 04:14 PM
A383Wing's Avatar
A383Wing
I didn't say anything about ball joints....I was referring to the front strut.
How do you check for play inside the steering rack? If it's a bad rack, you need to jack up the car and try to work both front wheels side to side. If you have one wheel that has movement, and not the other....it's not the rack. Have you checked the inner tie rod ends?
Bryan
Old Oct 5, 2021 | 08:02 AM
omuroff's Avatar
omuroff
That looks horrible and dangerous. I would suggest you to not to drive the car before this is fixed. This is due to some sort of ruptured bushing probably. Could be rack but I would suspect tie rod.
mlee4984
Mar 9, 2019 08:42 PM
AoxoMoxoA
Sep 30, 2018 06:30 PM
pmsummer
Jun 10, 2013 04:15 AM
Braminator
Off-Topic :: Autos
May 28, 2013 11:36 AM
