R56 Headlight bulbs
Old Feb 12, 2021 | 09:05 PM
Squidward18's Avatar
Squidward18
Headlight bulbs
I have a 2013 Mini Cooper s r56 factory headlight housing and bulbs looking to get any suggestions and opinions on some brighter lights as I have a hard time seeing and doesn’t look like my lights are even on most times, not looking to spend an arm and a leg on it looking for some suggestions please.
Old Feb 13, 2021 | 04:01 AM
Capt_bj's Avatar
Capt_bj
https://www.sylvania-automotive.com/...ltra/index.jsp
I've used these for years ... avail at most any parts counter .... these don't produce TOO MUCH HEAT
which is a problem I've seen with some other BRIGHT bulbs: I've seen light housings 'cooked' by bulbs that generated too much heat and melted insulation off internal wiring causing shorts which ruined the light housing . . .
Old Feb 13, 2021 | 06:24 AM
Squidward18
Thank you I have been looking at those wanted to make sure people have used them before.
Old Feb 13, 2021 | 09:10 AM
Gubi's Avatar
Gubi
The problem isn't the bulbs, it's the halogen headlight assemblies themselves: they're garbage. Higher output lamps will help a little, but not that much.
The real fix is to replace the headlights with halogen projector or do a xenon retrofit. I've tried them both and either is way better than the stock halogens, which are just junk.
Old Feb 19, 2021 | 08:39 AM
Get this kit, helps a bunch. And they are on a huge sale.
https://www.ecstuning.com/b-genuine-...63102347698kt/
Old Feb 25, 2021 | 03:41 PM
930 Engineering's Avatar
930 Engineering
These are most probably the only non-compromise and certainly the best available solution for Halogen equipped 2nd gen Minis.
Old Mar 5, 2021 | 11:52 AM
Yep, i don think i could go back to a halogen MINI headlight car and if i did i would swamp the lights.
theyboosting
Dec 10, 2019 01:19 PM
The Angry Pumkin
Oct 22, 2012 10:22 AM
DaveKennedy
Apr 12, 2012 10:45 AM
