R50/53 No fire on 1 and 2
Old Dec 29, 2020 | 02:23 PM
Matt Staggs's Avatar
Matt Staggs
No fire on 1 and 2
A while back my 2010 non turbo Mayfair edition 110k miles would occasionally flash the oil light, added oil and continued, turns out too much oil was put in. It started running rough, pulled plugs abs they were all rough so I replaced them along with one coil that pulled apart while trying to get it off the plug. Also did an oil change and put in proper level.
It is currently only firing on cylinder 3 and 4. The only codes that are coming up are p0300, p0301, p0302. I'm gettin voltage to each coil, I can switch the coils from 3 & 4 to 1 & 2 and nothing changes, dead on 1 & 2, fine on 3 & 4.
Thoughts?
Old Dec 29, 2020 | 03:38 PM
Matt Staggs
also if I pull the plugs they are saturated in fuel.
I've also pulled both vanos solenoid, cleaned (one was gummed up), swapped them for each other and no difference.
Coldstart
Mar 23, 2019 02:57 PM
MarshallMotorsSC
Aug 1, 2018 05:20 PM
sarom058
Aug 3, 2016 01:41 PM
Wanderininla
Feb 4, 2016 01:06 PM
peter314
Oct 9, 2011 11:05 AM
