R56 2012 Mini Cooper S Timing Chain Kit
I was wondering what brand would you recommend? IWIS?
Problem: I have white smoke coming from the exhaust and wanted to replace my head gasket, even though it passed the leak test performed by one of the technicians. Since i am taking out the engine, might as well replace the timing chain. Any step by step for replacing head gaskets? Not really seeing it for 2012 Mini Cooper S on Youtube.
Then for a "how to" source, the newTIS web site is the most popular set of repair instructions --- https://www.newtis.info/tisv2/a/en/ it has procedures used by most dealer shops. 2nd choice would be the Bentley manual. Since you're asking newbie questions, you probably don't know about the illustrated parts catalog fo Mini's --- https://www.realoem.com/bmw/enUS/select great source for getting part numbers when ordering parts online. As for you-tube, use it as a guide only. Many use shortcuts or don't show all the necessary steps.
If you really want to DIY repairs, be sure you have access to all the special tools. It also helps to have a Mini-knowledgeable friend to lean on while you get familiar with your new toy. If there's a local Mini car club nearby, I suggest you join it --- really helps the learning process.
OK, I'm making assumptions here, so one more please --- Even if you have lotsa engine knowledge and repair experience, Mini's have a unique timing setup. You need to understand it before doing anything that will affect engine timing. This is considered an "interference" engine (valves can contact pistons if timing is off) some mistakes can destroy valves. Re-assembly sequence, bolt usage and torque values, proper use of the special tools, all are critical when setting engine timing.
I strongly recommend you live with the smoke until you understand what to fix and how to fix it.
Thank you for your reply. The information is very helpful.
I'm not sure how else to diagnose the white smoke from the exhaust. It passed the leaked test and pressure test performed by a technician from the Mini dealer. There is no leak anywhere. I am getting some OBD faults like Car Access System CAS, Motor Electronics DME, Driver's Side Footwell Module FRM, and Automatic Heating/Airconditioning KLIMA. Could it be the thermostat?
I do have a service light due for Brake fluid flush.
The service light for brake fluids comes on two years after it's last reset. There is no sensor in the car that makes it come on.
IWIS is the same as Genuine MINI.
Its stamped on most of the parts, you can see it on this tensioner.
entropy1
May 1, 2016 11:57 AM
