R56 Help identifying brakes
Old Jul 28, 2020 | 10:25 PM
hxkenneth's Avatar
hxkenneth
Hello. Can anyone help me identify the brakes on my R56 MCS so I can buy the right pads and rotors for it? I inherited these from the previous owner.
Old Jul 29, 2020 | 11:31 AM
3lusive's Avatar
3lusive
Last 2 pics look like the stock rear brake calipers. Not sure what the brembo branded caliper is though
Old Jul 29, 2020 | 11:43 AM
CakeEater's Avatar
CakeEater
I agree with the above post the last 2 look like stock rears, but you should measure the diameter of the disc to see if it is a JCW disc or a regular mini cooper s disc. Pads should be the same regardless on the rears.
The front looks like the brembo gt 4 pots
https://www.ecstuning.com/b-brembo-p...a1.6029a3~brm/
So you have a 328x28 rotor and for pads I THINK they are the same pads used as the JCW 4 pot brakes, but dont quote me on that because it could be wrong. I also found replacement pads for you on ECS but couldnt find specs for them to match to JCW 4 pot pads
set 1 https://www.ecstuning.com/b-brembo-parts/brembo-calipers-lotus-a-c-f-street-brake-pad-set-brembo-oe-st04-
ceramic/st17r592t15sco~b/
set 2 https://www.ecstuning.com/b-brembo-p...107864516~brm/
Let us know how it goes
Old Aug 1, 2020 | 01:07 AM
hxkenneth's Avatar
hxkenneth
Thanks gents. I'm also quite sure the rear are stock and its good to know what the fronts are now. I'll try the suggested parts though pads seem a tad expensive.
The JCW pads here but not sure if they'll fit: https://www.ecstuning.com/b-genuine-...w/34116789157/
Old Aug 6, 2020 | 08:34 AM
Yep those are the pads if you have the JCW factory four piston front brakes. Made my brembo. I Have those.
Old Aug 6, 2020 | 11:00 AM
hxkenneth's Avatar
hxkenneth
I actually have the Brembo GT brakes though, as someone else has mentioned above. What would be a more affordable option for pads and rotors for the Brembo GTs?
Old Aug 7, 2020 | 03:18 AM
knt's Avatar
knt
If you know the size try Mintex pads and Brembo OE brake disc for day to day road use as they're not that expensive compared to other brands.
Sstrickstein
Tires, Wheels, & Brakes
Mar 23, 2016 09:28 AM
flannelhippie
May 1, 2012 05:19 PM
dustris
Feb 12, 2010 08:36 AM
jeffm5150
Classic Mini Talk
Oct 10, 2009 09:31 PM
DreamWeaver
Jun 27, 2006 04:08 PM
