R56 Help with part identification
Old Apr 1, 2020 | 09:54 PM
xbob's Avatar
xbob
Aloha everyone, I'm Bob, live on Kauai. Hoping you and your families are all healthy.
Need help identifying a part. My wife owns a 2015 Cooper base hatchback, 4 cylinder, 6 speed manual, so I think that makes it the R56 series. She's had it for 5 years now and it has 38,000 miles.
It was almost perfect, until yesterday, when she managed to misjudge and drive over a landscape rock. It ripped a piece of metal from underneath, and I'm trying to ID the part name. The piece is metal, probably aluminum, and is silver colored. Before it got crunched, it appears to have been fairly flat. When I lie on the ground at the drivers door, and look underneath, it appears to have been attached at about the midpoint left to right and front to rear of the underside of the car.
I'm thinking that is is some sort of heat shield, or an under body protective pan.
I've looked at several online parts catalogs and have not been able to ID the part. I also called Mini of Honolulu and talked to the parts department, and they were not able to ID it either.
Any ideas for the name of the part, or even better, a part number?
mahalo
Bob
Old Apr 2, 2020 | 04:12 AM
giorgos's Avatar
giorgos
Photos of the part and, if possible, from underneath the car would help.
Also: are you sure it is an R56? Both R56 (second generation) and F56 (third generation) have four cylinder engines (the F56 may also come with a three cylinder engine) and a manual 6 speed transmission. But production of the R56 (3-door hatchback) ended in November 2013.
Old Apr 2, 2020 | 06:41 AM
Yep , need photos and i should be able to find it.
Old Apr 2, 2020 | 12:35 PM
xbob's Avatar
xbob
Shoots, I thought I was in the right group - can't keep these Mini models straight. I reposted to the F56 group, but here are the pics of the mangled piece..
one side, with fastener
other side, with the fastener
Old Apr 2, 2020 | 12:55 PM
giorgos's Avatar
giorgos
This looks like the heat shield of the exhaust:
https://www.newtis.info/tisv2/a/en/f...cer/1VncIWhI22
https://www.realoem.com/bmw/enUS/sho...diagId=51_9653
Prior to ordering any parts, make sure that they fit for your particular car/model.
Old Apr 2, 2020 | 01:09 PM
That is either that small front of the main section/
F56 MINI Cooper, looks like this
Parts for F56
Small front #1 in the diagram
https://www.ecstuning.com/b-genuine-...l/51487290782/
#2 https://www.ecstuning.com/b-genuine-...r/51487290777/
pop you head under their and see whats missing.
Old Apr 4, 2020 | 09:55 AM
danraabe's Avatar
danraabe
That is heat shielding for the exhaust. They come in 2 pieces - front and back. You will have to remove the exhaust pipe south of the down pipe to replace it. You should replace both pieces so they fit properly. Best.
ericfreeman
12
May 18, 2017 05:56 PM
jmb2232
Apr 11, 2016 08:57 PM
pyromanfo
Jun 6, 2010 10:05 AM
jimenezMini
Oct 18, 2008 01:13 PM
allforknot
12
Mar 18, 2007 10:59 AM
