R56 Bimmercoding the Gen 2?
Old Apr 24, 2019 | 11:36 AM
Crossingover's Avatar
Crossingover
Just picked up a 2013 base Cooper and went to try to connect it with my Bimmercode app; no go. That app works wonders with our F60. I looked up compatibility and it picks up with Gen 3 apparently. What are folks using to code their Gen 2's? I searched forums here and everything popped up in the Gen 3 forums. Thanks.
Old Apr 24, 2019 | 11:52 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I use Carly app on my iPhone for my R55.
Old May 2, 2019 | 11:45 AM
scottselk's Avatar
scottselk
Ditto I use Carly on a android to change things like window roll up, unlock all doors, ETC.
Old May 3, 2019 | 07:44 AM
Yupetc's Avatar
Yupetc
Yeah I just got my deepak ble and bimmercode wont' work with it.
Old May 3, 2019 | 10:14 AM
Crossingover
Thanks for the input folks. I was hoping my Bimmercode app would work with a Gen 2 as flawlessly as it does with the Gen 3. I read mixed reviews of Carly so I'm still undecided.
Old May 9, 2019 | 07:35 AM
Crossingover
Still undecided on the coding tool, but did get a Foxwell 520 scan tool and will play with it even though there is very limited coding capability possible.
Old May 10, 2019 | 12:24 PM
cloverasx's Avatar
cloverasx
I have a 2012 r56s and I was able to code my key to roll the windows up with some other app that I can't remember the name of now and just a cheap bluetooth OBD2 adapter. Do you guys know if there's any way to have the windows (on mine) roll up/down all the way without having to hold the button?
Old Dec 2, 2019 | 03:40 AM
871 MCS's Avatar
871 MCS
bimmercode app +
Amazon Amazon
on my 2010 R56....i have coded a few things already...the one thing that i can't get coded is the disabling of the bulb checks, since i replaced every exterior lamp with leds, except the headlights.
Old Dec 2, 2019 | 06:33 AM
maccoder's Avatar
maccoder
I did successfully use Bimmercode.app (iOS) with Veepeak OBDCheck BLE+ adapter to do a couple of tweaks on 2013 R56 MCS.
Old Dec 2, 2019 | 07:34 PM
joedotmac's Avatar
joedotmac
Which module did you successfully connect and modify on the '13 R56 MCS? With Bimmercode I'm unable to connect and modify the footwell module.
Old Dec 3, 2019 | 05:51 AM
maccoder's Avatar
maccoder
I have changed the one-touch turn signal duration to 5. This setting is in Footwell module. Also tweaked couple of settings in Instrument Cluster.
Which adapter are you using?
When you say you are unable to connect, do you mean you can't connect Bimmercode.app with adapter at all, or is it just a Footwell module showing as not supported (similar to Headunit in my screenshot)?
Modules that Bimmercode.app can see.
Successfully modified value in Footwell module.
Old Dec 3, 2019 | 04:16 PM
joedotmac's Avatar
joedotmac
I'm using Bimmercode on iOS in conjunction with the Veepeak OBDCheck BLE+ on a 2011 Mini Cooper S. Attempting to change the cold and warm monitoring checks for the front and rear parking/turn signals and rear brake lights.
Upon connecting Bimmercode to the OBDII reader receive a green status indicator on all modules but the head-unit section. Attempting to connect to the footwell module ends with a pop up error message...below.
Reviewing the Supported Coding Options on the web site under the voltage section indicates support for the functions I'm attempting to change.
Old Dec 3, 2019 | 05:12 PM
maccoder's Avatar
maccoder
Yes, these options do show up for me under footwell module. I have a feeling I've seen this error mentioned somewhere. Possibly on some other NAM thread. Try searching for it.
Was your car coded previously by any chance using different tool?
Maybe contacting app developer can shed some light on this issue?
Old Dec 3, 2019 | 05:57 PM
joedotmac's Avatar
joedotmac
There's been no coding on the car that I've performed. The previous owner, I can't be certain. I sent the Bimmercode email address a support request earlier today so we'll see what happens there. I'll search for the error in the forum to see if I get any additional info. Thanks.
Old Dec 3, 2019 | 08:01 PM
joedotmac's Avatar
joedotmac
Was able to resolve the issue. Using a Schwaben code scanner, found four codes stored. Wish I would have recorded or saved them. There was a fault in the FRM (footwell) module. Cleared all codes. Was unable to connect to the OBDII BT adapter, not sure why. Started ran the car for about 5 minutes. Shut off the car. Then I was able to connect to the OBDII BT adapter and view the configuration list under the footwell module. Undoubtedly fault state of the footwell module was preventing Bimmercode from being able to pull data from the module. Thanks!
Michael DeJesus
Jul 15, 2017 09:40 PM
johntotah94
Apr 12, 2017 02:43 PM
cadfael_tex
R57 :: Cabrio Talk (2009+)
May 10, 2009 02:32 PM
Herby74
Oct 7, 2008 09:59 AM
