R56 UPGRADE to ECS OEM Side Mirror glass... auto dim, heat, blindspot??
Old Mar 27, 2019 | 04:58 PM
mountainhorse's Avatar
mountainhorse
Saw this post from ECS...
Pricey...but.... HUMM.
What makes them dim? 12-Volt applied to connector... If so... a simple relay can drive that from the a PV cell or the headlight circuit.
HMM...
Thoughts ??
R56-R59 Blind Spot Mirror Electrochromatic - Set ( If you only already have the auto dim side mirror option ) 2011+ MY
http://www.ecstuning.com/Search/SiteSearch/51169803799KT/
Old Mar 28, 2019 | 05:21 AM
There for pre wired cars, like a direct swap for cars with those options. I have had people run wires and mod them to make them work. I dont think anyone ever posted up on these. If you have the auto dim in the center mirror already then you could tap those lines. Its need a solar sensor to work.
Old Mar 28, 2019 | 02:08 PM
mountainhorse
Hope to draw on my Fellow Nam'rs experience here...
Where would I find a factory wiring harness for these mirrors.
Old Mar 29, 2019 | 09:06 AM
This is all the info i have: https://www.northamericanmotoring.co...ml#post3872772
Then the TIS here: https://www.newtis.info/tisv2/a/en/r...er-s-all4-sav/
Good luck and I hope you can make it work.
actulsiz
Jan 15, 2014 05:14 PM
mikeyut3
Electrical
Nov 22, 2012 12:28 PM
Jonathan
Mar 9, 2006 09:33 AM
