R56 2011 vs 2012 n18 pcv vent hose
Old Feb 6, 2019 | 07:44 PM
Xjsf28's Avatar
Xjsf28
Just out of curiosity, why is it that in 2011 the pcv hose on the n18 (r56 mcs) connected to the turbo inlet pipe was never installed, however on the 2012 models the hose is there. This may be a stupid question, but what would deleting that hose on the 2012 variant do?
Old Feb 7, 2019 | 11:23 AM
Pics? I know they added one hose and sensor late in the 2013.
Old Feb 7, 2019 | 07:17 PM
cyberlunacy's Avatar
cyberlunacy
the hose from the valve cover is in the front of the engine and directly goes into the intake hose which connects to the turbo inlet, like inches away from it.
there is no true pvc of olden days on the N18's i consider it be more of a valve cover breather line, not the old PVC which pukes out gallons of oil over time.
no clue what the sensor is that plugs in at the base of it by the turbo, maybe more air blow sensor-ing ?
thats the line on the N18 that people splice into an oil catch can that does no good on good engines(i say that loosely because my tube barely has any residue in it, not even enough to consider an immediate need for an oil catch can. though the turbo sucks like a mother f'er, it may very well be sucking the oil out of the line but given the current state of my oil change two months ago, mine aint burning any oil.
Old Feb 7, 2019 | 10:06 PM
Xjsf28's Avatar
Xjsf28
this is a pic of my 2012 mcs and it has a 2nd line that's really f****ng me over because now I'm going to have to drill a hole in my newly used aem intake. So I'm trying to look for alternatives so i want to find an alternative
Old Feb 8, 2019 | 03:33 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Sounds like you bought an N14 AEM intake, and not the N18 intake. The N14 version comes with the turbo inlet hose. The N18 version does not come with the turbo inlet hose because of the issue you are having.
N14 AEM intake:
https://www.aemintakes.com/search/pr...x?prod=21-699C
N18 AEM intake:
https://www.aemintakes.com/search/pr...x?prod=21-721C
Old Feb 8, 2019 | 03:45 AM
Isyvibes's Avatar
Isyvibes
Get a splitter like this.
Can probably by the splitter and resistors to jump out the heaters from nm engineering. See the instructions for there intake on how to use them. http://bd8ba3c866c8cbc330ab-7b26c6f3..._NM.658858.pdf
Old Feb 8, 2019 | 06:02 AM
Xjsf28's Avatar
Xjsf28
do you have any links to any that are fairly cheap but still good. And yes I know I got an n14 intake when I first bought it but these intake usually go for anywhere from $550-$800cad and I managed to get mine for $300 knowing that I'd have to modify it. So I'm just want some options as to what I can do.
Old Feb 8, 2019 | 06:23 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
One option is to not use the turbo inlet pipe that came with the intake...
Old Feb 8, 2019 | 06:29 AM
Yep late in the 2012/2013 they have that little sensor. People get the N18 forge silicone intake hose and then poke a small hole in it to insert the hose. If its a had pipe you will have to tap in on another part that is close or silicone. https://www.ecstuning.com/Search/SiteSearch/FMINLR60/
Yes on the AEM, most intakes avoid that because of the change.
Old Feb 8, 2019 | 10:20 AM
Xjsf28's Avatar
Xjsf28
I have the tools to tap into the aluminum pipe, would there be any issues with attaching the sensor to the metal pipe instead? The aem pipe is just so good looking 😂
Old Feb 8, 2019 | 10:40 AM
Hole has to be tight and no air leaks. Then you are fine. Put it around the same location.It has a little gasket but i would seal it or put a rubber gasket on the outside. On silicone it seals pretty good.
Old Feb 8, 2019 | 06:09 PM
Xjsf28's Avatar
Xjsf28
thanks ecs,
btw does it matter that it will be mounted to a rounded surface, or does it need to be on a flat surface like the maf sensor?
Old Feb 12, 2019 | 10:46 AM
Need to be in the air tube and closest to the original location, its does not matter as long as its sealed. Just dont want to see a CEL or vap leak code.
Old Aug 17, 2019 | 06:34 AM
ditc's Avatar
ditc
Hi,
Wanted to resurrect this since I have a similar issue. Does anyone know where to get those resistors to jump out these heater sensors as discussed here?
thanks
Old Jan 23, 2021 | 10:31 AM
Luis Rivera's Avatar
Luis Rivera
What was your solution?
I literally did the same thing, and I'm in the same dilemma, I don't know if drill a hole into the aem tube or get the sensors and the splitter.
what did you do bro?
Old Jan 23, 2021 | 04:30 PM
Xjsf28's Avatar
Xjsf28
Hello, I just ended up cutting the pipe into an elbow pipe so I could clamp the stock inlet tube up to it.
Old May 6, 2021 | 10:58 AM
rcolina22's Avatar
rcolina22
The dealership is wanting to charge me $1000 to replace the pcv. Is this hose the PCV? Or is it located underneath the manifold? I have a R60.
Old May 6, 2021 | 11:15 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
That tube is just the vent. The actual PCV system is integral to the valve cover. There is a round cap on the left side of the valve cover with a vent diaphragm that can be rebuilt. But, a fully busted PCV system requires replacement of the whole cam cover. At that cost, the dealer is likely quoting a full replacement valve cover.
PCV Repair Kit:
https://www.ecstuning.com/b-hamburg-...27646552v~ham/
Replacement N18 Valve Cover:
https://www.ecstuning.com/Mini-2012-...h/11127646552/
RCRacer
Jun 15, 2025 09:27 AM
whalejr31
Sep 1, 2019 12:52 PM
Neal3000
Sep 22, 2017 09:08 AM
Jeff Proctor
R55 :: Clubman Talk (2008+)
Sep 28, 2016 01:15 PM
phillipcoopersgates
Sep 10, 2013 07:22 PM
