R56 Clutch Conundrum?
Old Aug 5, 2018 | 10:05 AM
sterlingarcher's Avatar
sterlingarcher
Clutch Conundrum?
Hi,
I recently picked up a 2012 Cooper S. The previous owner had put a SPEC clutch kit and lightweight flywheel in it. I didn't like the setup, so I had the shop put a stock dual mass flywheel and clutch kit back in.
However, the new stock clutch feels way stiffer (heavier pedal) than it should and it squeaks/creaks when I push the pedal. I'm taking the car back into the shop to see what's up, but any advice would be welcome. I was under the impression from reading on the forums and from talking to my mechanic that the new stock clutch would be pretty light and easy going, so I'm a bit confused. Maybe the shop used an old stock clutch kit that was laying around?
Thanks!
Old Aug 5, 2018 | 01:23 PM
downshift1's Avatar
downshift1
Usually a stiff pedal is caused by a few different things.
lack of lubrication on moving parts
Pressure plate spring stiffness usually caused by improper break-in or years of abuse.
Hydraulic issues.
I will say sometimes the aftermarket clutches can actually have softer pedal pressures than factory units of they use quality components.
Old Aug 5, 2018 | 02:06 PM
sterlingarcher
Thanks for the advice! I’ll follow up after I take it back to the mechanic.
Old Aug 6, 2018 | 01:29 PM
Subw00er's Avatar
Subw00er
https://www.northamericanmotoring.co...ky-clutch.html
Might want to read that too.
Old Aug 6, 2018 | 02:10 PM
sterlingarcher
Originally Posted by Subw00er
Thanks! Seems like it could either be the hydraulic system (master/slave) or... the throw-out bearing! Ugh. If it's the bearing the shop should replace it at no or very little cost. I mean, it would mean they installed it incorrectly or got a defective part from their supplier. I'll know more in a few days after I drop it off.
Grotah
R55 :: Clubman Talk (2008+)
24
Aug 28, 2008 06:29 PM
RVExotics
Jan 11, 2008 01:17 PM
RedSkunk
Suspension
15
Jan 22, 2007 04:01 PM
countrym
Tires, Wheels, & Brakes
19
Jun 24, 2005 12:07 PM
Innes
11
Oct 28, 2002 03:03 PM
