R56 R56 N14 Crankshaft Seal Tool
Old Jul 31, 2018 | 07:46 AM
slate83's Avatar
slate83
Do you have to use the Mini specific crankshaft seal tool when replacing the crankshaft seal on a 2008 Mini Cooper S R56 N14 engine? Has anyone use any cheaper alternatives successfully? Thanks in advance.
Old Jul 31, 2018 | 08:02 AM
Scudder44's Avatar
Scudder44
No you don't. Main things to note are the seal should not be removed from the sleeve it comes on and should be slid into place dry. You can tap it in gently with a wooden dowel or some members have used a plastic plumbing fitting from DIY store which are the perfect fit. I have no idea what size they used, plenty threads to search for it.
Old Jul 31, 2018 | 09:02 AM
jglover's Avatar
jglover
The Bentley manual also says to watch the depth in which you install the seal
Old Jul 31, 2018 | 10:03 AM
Scudder44's Avatar
Scudder44
There is a raised bit inside the aperture which stops the seal going in too far, you should measure the depth of your current one and insert to same depth is what Haynes recommend. Also clean the crank hub and aperture with solvent/petrol to remove old dirt and seal marks, again, do not oil anything before locating the seal. Dry fitting as per instructions that should be in the seal box.
jgq524@yahoo.com
Mar 16, 2018 02:55 PM
PelicanParts.com
Mar 2, 2017 10:45 AM
Blasbo
14
Jul 13, 2016 02:14 PM
grussell
R55 :: Clubman Talk (2008+)
Jun 19, 2015 09:21 AM
NC Doug
Oct 20, 2014 10:03 AM
