R56 Key fob problem
Old May 18, 2017 | 05:27 PM
rob_gendreau's Avatar
rob_gendreau
Key fob problem
I've seen a ton of answers about fobs, but I'm not quite sure I've got it sorted out, so I'm seeking some verification.
I've got a fob that hadn't been used in a while, I suspect, in the car. It's an R56, 2008. Shows some wear so did get used at some point. No convenience package; it's the kind with the rechargeable battery per the manual and appearance.
It won't open doors, but when in the key slot the car will start and run fine. But after a couple of 30 minute drives, still won't open locks.
I have concluded that the battery is probably shot, and probably won't accept a charge. But will it also continue to work for the forseeable future to at least start the car? I figure in the slot it does so, and I can always use the mechanical locks.
I assume replacing the battery is still a PITA, and way expensive to get a new one at dealer. Any way to get the battery to accept charge? Should I just keep trying?
Old May 18, 2017 | 06:25 PM
AZdsrt's Avatar
AZdsrt
Ya, the battery is probably shot. If so, not much you can do to charge it. Why they didn't use a replaceable battery is beyond me. The battery is not needed to start the car as I believe the car simply sees the passive transponder in the key.
There a couple of threads on here for a DIY battery replacement. The pics I saw show it a bit messy to do, but doable. I also recall a member that has a small business replacing the battery. Might want to do some more searches on NAM.
Old Aug 2, 2022 | 01:04 PM
SuperOriginalGuy's Avatar
SuperOriginalGuy
Oops. Wrong post.
Garconis
Mar 6, 2015 07:59 AM
fullymooned
Jan 22, 2013 09:09 AM
minirockett
Apr 17, 2012 01:08 PM
smoke05S
Electrical
Apr 7, 2012 06:29 PM
The QZ
Sep 4, 2010 11:04 AM
