R56 Methanol Kit
Old 02-22-2017, 04:09 AM
bman48's Avatar
bman48
bman48 is offline
Methanol Kit
I just purchased a snow performance stage 2 methanol Kit for My 2010 S with a stage 2 Manic tune. I Have questions regarding the setup.
Where is the best place to install the injector? I am using this for cooling so I can run Map C all the time. Thanks for the help In advance. Brett
Old 02-23-2017, 07:45 PM
lemarzmini's Avatar
lemarzmini
lemarzmini is offline
Are you going to tune the car with Meth? or you plan to just ad the kit as is?
check out this link to get a better understanding of the different placements
http://www.alcohol-injection.com/en/...jection-nozzle
Old 02-24-2017, 02:22 AM
bman48's Avatar
bman48
bman48 is offline
That is my question. Do I have to send the ecu back and have a tune for meth or can I just install the kit?
Old 02-24-2017, 02:43 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
Generally people install the jet in the pipe after the intercooler in the bend by the dipstick.
Old 02-24-2017, 04:34 AM
bman48's Avatar
bman48
bman48 is offline
Thank you!
Old 02-24-2017, 05:18 AM
thebombardier's Avatar
thebombardier
thebombardier is offline
Manic can customize the tune for meth. Though I believe Map C is designated for 100 octane, I don't know if a methanol kit will raise the equivalent octane up that much strictly through cooling.
Old 02-24-2017, 06:32 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
The methanol itself raises the octane.
Old 02-24-2017, 07:46 AM
bman48's Avatar
bman48
bman48 is offline
@cerenkov Thanks for the pic and help. Are you tuned with it or did you just install?
Old 02-24-2017, 10:31 AM
lemarzmini's Avatar
lemarzmini
I would recommend that you clean the intake valves before you install the kit.
If you already have carbon build up, it will create wet gunk when you spray meth onto the valves.
Another thing to bare in mind. After you tune your car with meth, the car will depend on meth, so make sure you never run out.
Old 02-24-2017, 11:32 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
I have a Manic stage 2+, map c for me is methanol injection or 100+ octane only. I've never used map C, don't want to know what I'm missing, lol.
For my meth kit (Aquamist hfs4) I've wired up the failsafes but have never set them to active since I'm always on map B and it's not required.
Old 02-24-2017, 01:43 PM
Tigger2011's Avatar
Tigger2011
Tigger2011 is offline
Alliance Member
Did the white or blue nozzle come with your kit?
Old 02-25-2017, 09:00 PM
BigBoost's Avatar
BigBoost
BigBoost is offline
Am waiting on getting my Aquamist kit. order it fr-day after noon!
Old 02-28-2017, 10:08 AM
JValenzSD's Avatar
JValenzSD
JValenzSD is offline
I remember Mario from Manic telling me to either put 100 octane gas or run Meth with Map C. It should provide the knock resistance needed for that tune.
I'm currently on Map C with E40/91 blend. Car runs like a champ.
Old 02-28-2017, 10:51 AM
BigBoost's Avatar
BigBoost
BigBoost is offline
Am running map C right now
on
70/30 e85 with no math
an before that
just on 93
an never had any problems
but I've never heard of the
100% octane thing
I know map c don't
like the stock
ko3's
in higher boost you can
definitely tell it's runing it's self out of air
Old 02-28-2017, 11:00 AM
JValenzSD's Avatar
JValenzSD
I'm seeing 22.6 psi on the factory turbo, but after 4krpms, it runs out of breath and the engine out flows the turbo.... Glad I have the JMTC S42 ported and polished ready for the install this weekend.
As for map flashing, I have the SPS which allows me to switch from Map A, B, or C. I don't have to send the DME back for a reflash. But for my Stage 3 tune after the JMTC S42 turbo install, yes, it will need to be bench flashed again.
Old 02-28-2017, 06:06 PM
BigBoost's Avatar
BigBoost
BigBoost is offline
I'm currently running like Frankenstein
k04
But for this summer
going to try out
the JMTC GTD 47mm
& jeff's meth kit'
turbo should be in tomorrow
an the meth kit should be here Friday
from what the tracking says !
only thing that sucks is I'm from northern Wisconsin
I have another month or so before I can even drive
Or even think about getting the mini out
