R56 Trouble code help
Old Apr 27, 2016 | 11:36 AM
ColoCoug's Avatar
ColoCoug
Trouble code help
My daughter's 2011 R56 (59K miles) did a 'reduced power" event last week, along with the engine light telling her that power had been cut back.
I checked codes with a Bavarian Technic code reader, which should be capable of pulling most codes - but the ones I found don't appear in any reference I can find.
I've Google searched, and also searched this and other forums for them, but I find almost no references to them and the one or two references I did find don't seem to be consistent.
The codes are:
2F7C
2F76
2DCE
I cleared the codes (which showed "error not present") and the engine light has not re-appeared, and the car has run fine - but I'd sure like to find out what those codes mean. They don't follow the more common P0XXXX format that most codes have.
Any references that I should check? Anyone know for sure what they mean?
Old Apr 27, 2016 | 12:22 PM
bheights's Avatar
bheights
Here is what shows up on Rheingold ISTA Diagnostic tool. Some have details (provided one for 2F7C) while others do not.
Attached Thumbnails Trouble code help-screen-shot-2016-04-27-at-12.01.13-pm.jpg   Trouble code help-screen-shot-2016-04-27-at-12.08.20-pm.jpg   Trouble code help-screen-shot-2016-04-27-at-12.08.40-pm.jpg   Trouble code help-screen-shot-2016-04-27-at-12.08.58-pm.jpg   Trouble code help-screen-shot-2016-04-27-at-12.09.22-pm.jpg
File Type: pdf
Old Apr 27, 2016 | 01:03 PM
oldbrokenwind's Avatar
oldbrokenwind
Here's a link to another source of Mini-specific codes --- http://blog.perrinperformance.com/mini-r56-dtcs-list/ Jeff Perrin is the guy responsible for the Mini version of Cobb's AccessPort. I trust his code descriptions.
It's not alpha-numeric (hexa-decimal numbering system), so might be difficult to find what you're looking for --- if it's there.
Old Apr 27, 2016 | 07:05 PM
ColoCoug's Avatar
ColoCoug
Thanks, gents.
I don't know what evil genius came up with these - I count 10 versions of 2F7C (most relating to Super-Knocking, a new term for me) 18 of 2F76 (mostly ambient pressure sensor), and 6 of 2DCE (no message from ASC/DSC or Valvetronic system, no adjustment possible.)
I suppose options are always good, right? But none of these appear to be actionable at present.
Research on super-knocking seems to indicate it may result from carbon build up on the valves. At 60K miles, that's a possibility. Might be a good time to use Techron and valve-type cleaners.
Old Apr 28, 2016 | 08:11 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
P1030 0x2DCE Valvetronic system: Closed-loop control deviation too high
P137F 0x2F7C Knock Control Fuel Cutoff Due to Super Knocking
P13A0 0x2F76 Super-knock on Cylinder 1: Injection deactivation
What your scan tool is giving you is the MINI FC code. Here are the associated P codes with them. These are all the other MINI FC codes can be found in the Bentley Manual HERE. We have a tech article that goes over the 2DCE valvetronic fault code. This is from our article:
If fault codes 2DCE and 58A2 are displayed, reprogram the vehicle using ISTA/P 2.30 or higher (integration level 1203500 or higher). Disregard fault code 2DCF at this time, and do not perform any further repairs related to this fault before programming.
I suggest you take a look at the article on our site: http://www.pelicanparts.com/techarti...nic_Faults.htm
888.280.7799 | 6am - 5pm PST
Old Apr 28, 2016 | 05:34 PM
ColoCoug's Avatar
ColoCoug
I suggest you take a look at the article on our site under MINI > tech info (tab at top) > R56 articles > Fuel Injection > Understanding Valvetronic Fault Codes. It should help you a bit. Let me know if you have any questions.
Great help, thanks! Will check article.
Old May 3, 2016 | 07:00 AM
Club77's Avatar
Club77
I got this fault code from Carly 00387F, engine motor power management, closed-circuit protection quiescent current injury. Can't find this code anyway trying to figure out what is the faulty parts. Anyone have idea thanks.
Old May 3, 2016 | 04:39 PM
Club77's Avatar
Club77
00C587 = CIC Gateway, Sleep-mode/Standby can´t be activated.
Old Sep 8, 2017 | 03:12 PM
Rufio702's Avatar
Rufio702
help
Attachment 124506
did you ever figure out how to fix it ? i have the same code
Fialee
Mar 18, 2022 06:44 AM
johntotah94
May 25, 2016 10:59 PM
Cmv138
Apr 11, 2016 06:18 AM
Oilfieldtrash
Apr 9, 2016 09:37 PM
Jorge Perez
Apr 4, 2016 03:13 PM
