R56 O2 Bank1 Sensor1 Failure. Need some guidance.
Old Apr 13, 2016 | 04:51 AM
GAT's Avatar
GAT
I recently swapped out my leaky turbo oil line plus a few other items which of course required me to remove the downpipe. Everything went smoothly, new gaskets and hardware was used where applicable, however I think I may have damaged my O2 sensor in the process as I used a deep O2 socket instead Mini version open sockets I've see online (i.e. ECS Tuning). My CEL is NOT illuminated and I have no current or pending codes but when I run OBD monitor tests (using different apps) I receive the below O2 related error. Am I correct in assuming that I need to replace my O2 sensor and is Bank1 Sensor1 the top sensor by the turbo?
O2 Bank1 Sensor1
Evap System Failure
Mechanical Info: 2007 MCS, 71k miles, 6 speed, Borla Cat-back, Alta intake, Alta boost tube, Wagner FMIC, Manic Stage 1+, freshly cleaned intake valves, new HPFP, new vacuum pump, fresh plugs, original coils, oil is always topped off and changed every 5k miles with, fresh BMW/Mini spec coolant.
Any help would be greatly appreciated. My registration is good through September but I assume I will not be able to pass inspection with this O2 error.
Old Apr 13, 2016 | 04:53 AM
GAT's Avatar
GAT
Here's a complete run-down of the readiness results:
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Test report:
MID:$01 TID:$83
- O2 Bank 1 Sensor 1
Max: 1.99882 Min: 0.24986
Test result value: 1.21024
PASS
MID:$01 TID:$84
Test incomplete or dependant test failed
MID:$01 TID:$93
Max: 0 Min: 1,033.70007
Test result value: 2,073.6001
FAIL
MID:$02 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 2
Max: 350ms Min: 0ms
Test result value: 100ms
PASS
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.44969V Min: 0V
Test result value: 0V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 1.15754V Min: 0.44969V
Test result value: 0.90439V
PASS
MID:$02 TID:$81
Max: 0.78666V Min: 0V
Test result value: 0.7769V
PASS
MID:$02 TID:$82
Max: 1.15754V Min: 0.78666V
Test result value: 0.79642V
PASS
MID:$21 TID:$81
- Catalyst Monitor Bank 1
MID:$3b TID:$81
- EVAP Monitor (0.090")
MID:$3c TID:$81
- EVAP Monitor (0.040")
MID:$3d TID:$86
- EVAP Monitor (0.020")
Max: 9.99393 Min: 0.06954
Test result value: 0.07198
PASS
MID:$3d TID:$87
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
MID:$50 TID:$e6
- O2 Heater Monitor Bank 4 - Sensor 4
Max: 41,358 Min: 10,256
Test result value: 20,736
PASS
quickcoop
Dec 4, 2020 09:05 AM
MINIMIKO
Mar 21, 2016 11:01 AM
RebeccaC
Mar 21, 2016 07:47 AM
quickcoop
Mar 19, 2016 12:41 PM
Hendricksen
Mar 18, 2016 07:37 AM
