High pressure fuel pump
Old Jan 10, 2016 | 06:37 PM
zrover's Avatar
zrover
Well after looking at many posts it sounds like I need to change out the high pressure fuel pump. Where do you guys buy yours, and where is it located and what kind of price are they? Thank you very much for your help!
Old Jan 10, 2016 | 06:39 PM
zrover's Avatar
zrover
Just for a little clarification I changed all the spark plugs all of the coil packs did a carbon cleaning. It was running rough right on startup that have to give it some gas it would run fine after sitting for a bit it would run bad it would run rough at stoplights give it a little gas and its fine. Does this sound like the high pressure fuel pump to you?
Old Jan 10, 2016 | 07:04 PM
sub3622's Avatar
sub3622
It does sound like hpfp. Any CEL? or codes?
FYI last week i was trying to help a friend to buy one and we were seeing very very expensive prices for hpfp´s, i even contacted ecs tuning because their prices were like $1,000+ and they told me that is factory that set the prices for genuine parts. I looked almost every single web page and the lowest prices were $800
Old Jan 10, 2016 | 08:31 PM
ctrlaltdl's Avatar
ctrlaltdl
Sounds like the same symptoms I was having. The dealer replaced the HPFP for free. They have an extended factory warranty on that part. Check with your dealer.
Old Jan 10, 2016 | 09:12 PM
akellogg65's Avatar
akellogg65
Check with the dealer, but they warranty is for a specific VIN range. I just replaced mine yesterday and it fixed the problems I was having. Now it starts right up without any coughing, sputtering or hesitation. No strong exhaust oder anymore. I bought my HPFP from Mini Mania here in California. I paid $336.00 for it in December but I just checked the website and now it shows it at $1128.00. Not sure what's up with that...... Super easy to replace. It took me less than twenty minutes. Good luck....
Old Jan 10, 2016 | 09:17 PM
zrover's Avatar
zrover
Thank you so much.
Old Jan 11, 2016 | 09:56 AM
sub3622's Avatar
sub3622
Like i said every web site has it for above $800+. Don´t know what is happening. Would like to know.
Old Jan 11, 2016 | 10:24 AM
nomarq's Avatar
nomarq
what are the symtoms did you get
prior to replacing your hpfp? mine will not start only crank, good battery, new plugs and coils, it cranks but no start, no issue prior to no starting. thanks
Old Jan 11, 2016 | 12:26 PM
Looks like a major price increase from MINI, these were high in price, then they dropped down in price, then shot way up. This is over the course of the last two years. We currently don't have any aftermarket solutions.
DIY is here for info and what to look for with issues.
https://www.northamericanmotoring.co...r-r56-jcw.html
Old Jan 11, 2016 | 01:24 PM
ceoengr's Avatar
ceoengr
Mini is attempting to recover all their losses due to the faulty pumps by jacking up the prices.
Old Jan 11, 2016 | 01:33 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
They went up so much last week as BMW bumped up pricing on a lot of items. We have one here (click and should highlight in green) that is still listed at a lower price. Might want to jump on it while it's still low. We also have a DIY that can help you with the replacement.
888.280.7799 | 6am - 5pm PST
Old Jan 11, 2016 | 01:48 PM
zrover's Avatar
zrover
Thanks to everyone for all the info. My car does start but after sitting for 10 to 15 minutes it sputters and coughs and won't start after I give it some gas and start driving its fine but initially it has a hard time the codes from the code reader are still misfire on all cylinders.
Old Jan 11, 2016 | 02:02 PM
Welcome, make sure if not something else , check all plugs , coils , rear pump. Lines and electrical. Then go to the HPFP. That way you can pin point it before you have to spend money. Our link above has all the HPFP info to DIY and save.
Old Jan 11, 2016 | 02:04 PM
zrover's Avatar
zrover
I have already replaced the fuel pump in the tank the dealer did that last summer. All of the spark plugs and all of the coils I did myself I did a carbon cleaning this past weekend and now I'm thinking it's the high pressure fuel pump does that sound like it's what it is to you?
Old Jan 11, 2016 | 02:12 PM
Looks like you have it pretty narrowed down, Coil, plugs and then carbon blast, check the wires also in the engine bay, then HPFP. That would be my order.
Old Jan 11, 2016 | 02:17 PM
zrover's Avatar
zrover
How would I know if I need to replace the timing chain what type of symptoms would you look for?
Old Jan 11, 2016 | 02:25 PM
Timing chain:
Also certain years fall under replacement, if it has not been done,
https://www.northamericanmotoring.co...00-mini-s.html
You would either have the timing chain noise ( death rattle ) or have a shop or dealership measure the slack in the chain.
https://www.northamericanmotoring.co...ce-please.html
Old Jan 11, 2016 | 02:30 PM
zrover's Avatar
zrover
Ok as far as the timing chain what would my engine supposed to sound like? Right now as its running it sounds like a Volkswagen diesel engine
Old Jan 11, 2016 | 02:35 PM
Get the timing chain checked asap as well as checking your oil asap. Oil very low can cause that rattle noise also.
Old Jan 11, 2016 | 02:58 PM
PelicanParts.com
Vendor
The timing chain guides wear or break. This creates a dangerous situation. The timing chain guides do just that, guide the timing chain so there is little to no slack in the chain. If the chain is allowed to move as the result of a broken timing chain guide there is a chance the chain could jump and throw engine timing off. If this happens valves could contact the pistons and engine damage could result. The guides wear from lack of lubrication and running low on engine oil (be sure to check your oil). This can cause timing chain rattle at start up, noise when running and worse-case scenario a jumped timing engine. This noise is known as the "death rattle." We have a DIY that has a lot of information as well as a replacement guide.
Old Jan 21, 2016 | 10:14 PM
zrover's Avatar
zrover
Thanks to everyone who has replied to the posts...I change the high pressure fuel pump and the car runs like it is new! Easy 30 job
Old Jan 22, 2016 | 04:49 AM
Glad my link and the DIY helped.
Old Jan 22, 2016 | 09:46 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
For anyone still looking for a cheap pump we have the N14 pumps in stock much less than the $1100 price
http://www.waymotorworks.com/high-pr...7-r58-r59.html
Old Jan 30, 2016 | 11:52 AM
tag1260's Avatar
tag1260
I guess the DIYers are now paying for all the replacement pumps that MINI uses on the warranty. I think I'd trade off the car before paying that much. Is there any way to prolong the life of these if we already changed it out?
Old Feb 2, 2016 | 12:12 PM
zrover's Avatar
zrover
Not sure how to prolong it but I paid 316 fir my pump... look around in the web for best pricing.
