R56 For better traction and handling larger or wider?
Old Oct 22, 2015 | 09:34 AM
  #26
hsautocrosser's Avatar
hsautocrosser
All other things being equal, wider tires get more bite in a lateral direction. The contact patch shape has more aligned molecules interlocking with the pavement in that direction. For better forward grip the narrower tire has more aligned molecules in that direction. If that isn't intuitive, try comparing the effort to push an eraser width-wise and length-wise along a desk top.
The wider drive tire on dragsters is needed to handle the massive torque and aerodynamic loading from wings (when equipped) at an ultra low air pressure . The high load and low pressure increases the SIZE of the patch putting more molecules into play. Since plus size street tires require more psi instead of less, the same benefit cannot be derived from wider tires on a road going MINI.
Old Oct 22, 2015 | 09:52 AM
  #27
lex76's Avatar
lex76
Fantastic reply hsautocrosser! wow!
So all things being said it doesn't make much of difference at all. the larger diameter will reduce the acceleration.
So do you think changing the bushings can make a difference as someone suggested previously?
Old Oct 22, 2015 | 11:52 AM
  #28
hsautocrosser
You're welcome.
Firmer bushings can improve handling by reducing play in the suspension. Might help with acceleration as well although I have no experience with doing it for that purpose. I suspect your only significant change will come from stickier tires (that wear out faster.)
Old Oct 23, 2015 | 03:17 PM
  #29
Capt_bj's Avatar
Capt_bj
the answer is simple
look at a "race car" for Indi in the 50's
then look at one today
did the tire get taller
or wider
Old Oct 24, 2015 | 07:37 AM
  #30
JPMM's Avatar
JPMM
Originally Posted by gchin
Since you are in Toronto, as ambient temperatures get colder, typically in the 40-45° Fahrenheit range, summer performance tires lose a noticeable percentage of traction as their tread compound rubber properties change.
My 245 Star Specs get real slippery when the temps fall below 60*
Camden90240
Sep 28, 2020 12:09 PM
Crustyjoe
Tires, Wheels, & Brakes
Dec 9, 2015 03:33 PM
Jolio
Factory JCW Talk (2009+)
Sep 17, 2015 09:23 PM
user 739030
Sep 16, 2015 06:03 PM
Carwash
Sep 15, 2015 02:02 AM
