R56 Mini cooper S 2009 alarm won't come on
Old Jul 14, 2015 | 09:30 PM
eliseo1981's Avatar
eliseo1981
Hello everyone,
I recently purchased my mini a couple of weeks ago, had the clutch replaced by a good mechanic for 700 bucks (including labor) and everything is now working outstanding on it except for the alarm.
I am not sure if it is supposed to beep or honk when you arm the car, but it doesn't. It does however lock the car. I also tried holding the trunk open button to see if the panic honking starts (says it will in the manual) and it doesn't. In addition the little light on top of the RPM's gauge does not blink or even come on when locked or unlocked. I even tried locking the car with the windows open and putting my key far away (as its one of those keys you can start your car without it as long as it is within proximity) and opened the door from the inside and no beeping or anything.
Is there a fuse, setting or something I should look at? The horn works by the way if I press the horn so not sure if the alarm uses that same horn.
Old Jul 14, 2015 | 10:31 PM
a2oc's Avatar
a2oc
It sounds perfectly normal Because your MINI doesn't come with an alarm. IT just come with a immobilizer as standard. If your car is built before Sept 09, your car should be 'pre wired' for the alarm. What it means is you can fit the alarm without a big hassle. In order to make the alarm operable, you need to get an alarm retrofit kit and find someone to code it. Or if you just want to make the LED blink, you can just code it. Panic alarm is only available if you have the actual alarm. The alarm will not blow the horn, it uses an independent siren that beeps really cute when lock and unlock, but really scary when its activated.
Old Jul 15, 2015 | 07:58 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Sounds like you don't have an alarm. You have to have the kit installed and then coded to the car to make the light flash on the tach, and beep when you lock.
We have an affordable kit if you end up wanting to add it, you just don't use the cabrio sensors. But it will give you the beeping.
http://www.waymotorworks.com/alarm-k...nvertible.html
Old Jul 16, 2015 | 12:28 AM
eliseo1981's Avatar
eliseo1981
Thanks guys, WayMotorWorks, so if I get this alarm do I still have to get it coded at the dealer? In addition will it make the tach light do the nice heart beat flashing?
Old Jul 16, 2015 | 06:37 AM
Whats the production date on the 2009 ?
There is an early alarm and a later version in 2009 : 65120443179 vs 65730445530
http://www.ecstuning.com/Mini-2009-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Exterior/Alarm/
Old Jul 16, 2015 | 04:14 PM
eliseo1981's Avatar
eliseo1981
I don't know the manufacturing date but looked at the door and it said the following.
Aug 10/08
the car is a 2009 so I am guessing they manufactured it in August of 2008
Old Jul 16, 2015 | 04:32 PM
a2oc's Avatar
a2oc
looks like oct 08 to me.......... MM/YY
Old Jul 16, 2015 | 05:10 PM
eliseo1981's Avatar
eliseo1981
that's what I thought but it said "AUG 10/08"
So unless AUG means something else, perhaps an acronym in german for manufacturing date :P
Old Jul 16, 2015 | 05:18 PM
a2oc's Avatar
a2oc
try the vin decoder
http://www.bmwarchive.org/vin/bmw-vin-decoder.html
It can tell you everything about your car. By the mfd year, your car does sounds like pre wired for the alarm.
Old Jul 17, 2015 | 08:23 AM
Yep so it looks like you need the 65730445530 MINI part version ( For vehicles with production to 9/2009 ) lined above .
Old Jul 17, 2015 | 04:49 PM
eliseo1981's Avatar
eliseo1981
checked the VIN's website and it does show Oct 2008, thanks for that info. So ECSTuning, does that mean that if I buy this will it make the little blinking light come on (on top of the tachometer)? Do I need to take it in to the dealer to get anything programmed?
Old Jul 19, 2015 | 07:20 PM
WayMotorWorks
Vendor
Yes you have to have the car coded after install. When you get it coded the tach light will flash and the car will beep when you lock and unlock it.
Old Jul 20, 2015 | 05:33 AM
Yes, its will need coded. Then it will flash the led light and have the audio beep when you lock and unlock. Its pretty loud.
Old Jul 25, 2015 | 05:23 AM
Ender's Avatar
Ender
thats a understatement lol i bough a 09 minicooper 25 days ago and found out the hard way that mine had the alarm installed.. ugh scared the poop out of me.. but the red light thats cool mine dosent really blink kinda fades in and out looks sweet in the dark.
Old Jul 25, 2015 | 10:05 PM
WayMotorWorks
Vendor
If you think it's too loud you can disable the beep in the tach using the key settings. It will be the padlock with the speaker next to it options.
Old Jul 26, 2015 | 05:57 AM
Ender's Avatar
Ender
beep is fine it was the alram i going off i didnt know i had scared me i was trying to figure out the key fob and held one of the buttons to long.
Old Jul 27, 2015 | 02:08 PM
Yea, its a heartbeat single pulse. Then after about 10 mins its starts to blink on and off a couple seconds.
Old Jul 11, 2025 | 07:20 AM
MINI still has these under a killer deal. For vehicles with production to 9/2009. The 9/2009+ version is nla.
https://www.ecstuning.com/b-genuine-...t/65730445530/
nomar116
Aug 9, 2015 09:42 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
