R56 R56 start up issues
Old Jun 25, 2015 | 01:08 PM
Englaish Matt's Avatar
Englaish Matt
R56 start up issues
Hi Everyone, I hope someone out there can give me some (sensible) advice.
I have an 08 R56 Cooper S. The original engine blew, new engine has about 15,000 +/- miles on it.
The car has a new turbo, K&N cold air kit, 3" Turbo back exhaust, large aftermarket intercooler. I have a stage 3 tune on it from Cob. All else is stock.
When I put the new (used) motor in (13,xxx miles), it ran like a dream for about 8 weeks. At 3k rpm it takes off like a jet.
Then every so often, it would run like a pig on start up, even throw a check engine light. Id read the fault codes , clear them etc then it would be fine again.
First it did it only in very cold weather, if it was warm, no problem - Now it does this every time I start it, once its warmed up, it runs like a watch - perfect, and even more fun in sport mode.
Spoke with Cob, they said to check the plugs, probably incorrectly gapped.
bought new plugs, gapped them per recommendations - started it, same issue. Please let me know any suggestions ( not stupid comments please)
I'm frustrated and want to get thoughts from anyone kind enough to reply......
Thank you!
Matthew
Old Jun 25, 2015 | 08:04 PM
minivinnie92's Avatar
minivinnie92
R56 start up issues
what are the codes that you are pulling? That might help us out a bit. That definitely doesn't sound like plugs to me sorry Cobb
Old Jun 25, 2015 | 08:41 PM
Joeygonz's Avatar
Joeygonz
Hpfp
I had the exact same issue on cold start until the HPFP was replaced.
When the engine sits for more than a few hours (at work or overnight) it will struggle to maintain an rpm reading as if it would stall. Very frustrating since once I arrived at the dealership, under warranty, the issue was camouflaged because the engine was warm.
Good luck and I am sure some here will chime in with a technical explanation as to why.
Old Jun 26, 2015 | 03:47 AM
Indimanic's Avatar
Indimanic
HPFP as a educated guess. I have personally seen a dealer try to deny the issue.
Very common and under an extended warranty
Old Jun 26, 2015 | 05:08 AM
chappybmode's Avatar
chappybmode
Add one for fuel pump
Old Jun 26, 2015 | 09:17 AM
minivinnie92
R56 start up issues
o I completely agree with the fuel pump but he obviously is getting a code for something could be related or unrelated but it'd be nice to know before we guess lol
Old Jun 26, 2015 | 02:52 PM
Englaish Matt
Gents, Firstly thank you so much for your responses!! I'll get the codes - I did have a fuel pressure code, but the pump was replaced with a new one, and it was ok for a while - could a pump go bad in 2,xxx miles? Ill be back at you all.
Thanks again!
Regards,
Matthew
Old Jun 26, 2015 | 05:21 PM
minivinnie92
R56 start up issues
I wouldn't exactly rule it out but I'd highly doubt it I've seen new parts fail out of the box and some weeks down the road never a hpfp but again wouldn't cross it off the list
Old Jun 27, 2015 | 02:04 AM
Systemlord's Avatar
Systemlord
Thanks again!
Regards,
Matthew
There are some member's on their 3-4th HPFP.
Old Jun 27, 2015 | 04:35 AM
minivinnie92
R56 start up issues
ya that's y I wouldn't rule it out especially with a code for it
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Teh
Jun 13, 2018 02:59 PM
makg
Aug 21, 2015 02:49 AM
