R56 TPMS warning problem
Old May 25, 2015 | 12:08 AM
PSU 98's Avatar
PSU 98
Since I've owned this car I cannot get the TPMS warning light to shut off for any length of time. I've recently replaced the wheels & tires with brand new TPMS and gone through the reset procedure about 30 times, tire pressures are always spot on and yet the light continues to illuminate. Any suggestions for a fix?
Old May 25, 2015 | 12:17 AM
a2oc's Avatar
a2oc
the receiver has gone wrong? its a grey boxlocated in the trunk left access panel., mounted on top of the left rear wheel arch
Old May 25, 2015 | 05:27 AM
mbwicz's Avatar
mbwicz
I had an intermittent 'inactive' warning on my system. It turned out to be a bad receiver in one of the front wheel wells. Have your dealer (or a competent independant) look at the system, they can tell you what transmitter/receiver is not working properly.
Mike
Old May 25, 2015 | 11:11 PM
PSU 98's Avatar
PSU 98
So are there 4 of these receivers or just one?
Old May 26, 2015 | 02:47 AM
mbwicz's Avatar
mbwicz
There is one receiver for each wheel, mounted in the wheel well. I know that the front ones are located under the headlight (they sit in a little pocket), but I'm not sure where the rear ones are located. They are about the size of a pack of cigarettes with a set of wires that plug into it. There is also a main module that is mounted in the trunk, as stated above.
Have fun,
Mike
Old May 26, 2015 | 05:48 AM
Capt_bj's Avatar
Capt_bj
what year?
early 7's still had the old TPMS that used the wheel speed sensor . . .
Old May 30, 2015 | 08:30 AM
PSU 98's Avatar
PSU 98
Originally Posted by Capt_bj
what year?
It is a 2007.
Dec 23, 2015 10:36 AM
hexproject
Sep 7, 2015 08:23 PM
DrFraserCrane
Aug 30, 2015 01:11 PM
Lschneider
Aug 21, 2015 02:21 AM
JamJam43087
Aug 16, 2015 02:02 PM
