R56 Desperate for help RE: xenon assembly part
Old Apr 21, 2015 | 12:04 PM
Lombomini2009's Avatar
Lombomini2009
Hello, I am in need of the part that holds the bulb in a bi xenon headlight assembly I don't believe parts in an assembly are available through the dealer. So I'm looking for a used assembly that's broken.
2010-2012 maybe later so I can remove.
I am very desperate, I bought a used assembly on ebay only to find out a piece was broken inside and the blub holder is missing. Picture I attached
shows the area that blub goes, missing bulb holder. NOT SURE WHAT TO CALL THE PART that I needDesperate for help RE: xenon assembly part-img_3618.jpg
Does anyone have a broken bi xenon assembly?
thanks
Old Apr 21, 2015 | 05:09 PM
sgscomps's Avatar
sgscomps
I believe the part you need only comes with the complete headlight housing. If you look at the diagrams on www.realoem.com they don't show seperate parts for the housing that hold the xenon bulbs in. Your best best to to buy a new housing from your MINI dealer or a trusted MINI part supplier.
Old Apr 22, 2015 | 10:35 AM
Yes, looks like it missing should have that bracket to hold the rear DS1 bulb .
What option do you have ? Silver headlights with clear turn or amber lens turn signal
Driver or passenger side ?
Old Apr 22, 2015 | 11:54 AM
Lombomini2009
bi xenon
Hello, right side, clear lens
thanks Dave
Old Apr 22, 2015 | 12:03 PM
Stock headlight with no cornering: non adaptive
right side : passenger: Clear turn lens w/ amber bulb : must use the three post ballast control unit 63127255724
http://www.ecstuning.com/Search/SiteSearch/63127270026/
Old May 1, 2015 | 06:30 PM
wick78's Avatar
wick78
Maybe buy a piece from theretrofitsource.com they have tons of pieces from oem headlights maybe they'll have one there. Doesn't hurt to ask
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
tr3y003
Oct 22, 2015 10:48 AM
