R56 Popping and gurgle exhaust???
Old Feb 12, 2015 | 10:37 AM
  #26
Grizld700's Avatar
Grizld700
They actually switched mid 2012 and some '12 JCW models do infact have the N18
Old Feb 12, 2015 | 10:45 AM
  #27
Ghetto Mr Bob's Avatar
Ghetto Mr Bob
Aha. Never knew that! I'll crawl back under my rock now.
Old Feb 12, 2015 | 01:06 PM
  #28
The Patagonian's Avatar
The Patagonian
Originally Posted by Ghetto Mr Bob
It pops/gurgles in sport mode because sport mode dumps a little fuel directly into the exhaust when it normally doesn't while not in sport mode.
On a side note, I've noticed the pops only happen after having driven the car for a certain distance. For example, if I only make a 2-3 mile commute in sport mode, no pops....if I stretch that to a few miles more, pops/gurgles all over the place.
That makes sense so it does change the map.
Agree about the distance but i suspect it's actually temp that triggers it, I need 5 or 6 miles on the clock before anything happens.
Old Feb 12, 2015 | 01:24 PM
  #29
AndyPWR53's Avatar
AndyPWR53
Fuel won't detonate unless the header/manifold/downpipe is hot.
Old Feb 12, 2015 | 02:07 PM
  #30
Ovrclck's Avatar
Ovrclck
Correct, once my temp gauge hits 90c, pops start.
Sent from cellular device.
Old Feb 12, 2015 | 02:24 PM
  #31
The Patagonian
Yep agree with that, I need about 190f on the Scangauge before anything happens.
Old Feb 12, 2015 | 06:57 PM
  #32
minivinnie92's Avatar
minivinnie92
I have to hit about 176-180f
Old Feb 12, 2015 | 10:05 PM
  #33
gchin's Avatar
gchin
I'm really enjoying reading all the comments about the MCS quirkiness!
It is pure driving pleasure, too.
Old Feb 13, 2015 | 12:31 AM
  #34
rigga's Avatar
rigga
My 2010 N14 jcw pops and bangs a lot, and as said only does it when its up to temperature, as there is no gauge fitted I use that as a sign the car is now ok to use properly, I was under the impression N18 engines only pop in sport mode which seems a bit of a backwards step, but not as much as the years they stoped doing it at all.
Old Feb 14, 2015 | 07:12 AM
  #35
Agbullet25's Avatar
Agbullet25
So what makes the JCWs pop over the MCS with the same engine? Is it a different downpipe or is it the different cat back section of the exhaust? Or is it simply the engine mapping is different?
Old Feb 14, 2015 | 09:23 AM
  #36
rigga's Avatar
rigga
Don't think the downpipe is different on the jcw to the cooper s, so its possibly exhaust (especially the rear silencer) I would think as I gather mapping is the same?
Old Feb 14, 2015 | 09:33 AM
  #37
minivinnie92
I doubt mapping is the same with a different turbo and exhaust and much more I'm sure it's programmed into the computer
Old Feb 14, 2015 | 09:34 AM
  #38
Agbullet25's Avatar
Agbullet25
I think mapping is a little different because there is an ECU remap needed when you get the factory tuning kit.
Old Feb 14, 2015 | 09:57 AM
  #39
rigga's Avatar
rigga
Probably right concerning the jcw mapping as there is a different Turbo,, I know the jcw rear silencer makes a big difference to the sound when fitted to Cooper s models though.
gmcnaugh
Oct 27, 2018 03:42 AM
xpunisherx
Nov 27, 2015 03:32 PM
embiggenedmini
Oct 15, 2015 12:36 PM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 2, 2015 09:05 AM
