R56 Catalyst Sys. Efficiency below threshold (bank 1)
I have a 2008 standard mini cooper with 55k miles and I'm getting code P0420 which is the catalyst system efficiency below threshold (bank 1). I'm not sure if this means that I must change the upstream O2 sensor or the downstream O2 sensor. please help, thank you!
The downstream (after the cat) o2 sensor determines catalyst efficiency. I would check for a warranty. I believe cats are covered for 8yrs or 80k under emissions warranty. But that may only be in California.
I had this same code on my other car (Subaru Outback), it was a cracked weld causing an exhaust leak upstream of the cat. Definitely check into warranty, mine was over 80K. I had it welded a couple of times but the welds failed, I ended up having to buy a new exhaust header and cat assembly.
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
kevinlhr310
Apr 25, 2018 05:08 AM
sirfrank
Sep 11, 2015 01:36 PM
