R56 2007 R56 Headlight Issue
Old Jan 25, 2015 | 11:35 AM
jsaum's Avatar
jsaum
I have an R56 Cooper with the driver's side headlight out. Changed bulbs to no avail. checked bulb in passenger side and it works. Is there a fuse somewhere associated with the headlights that i need to check? Or is it a wiring problem somewhere? Anyone have any issues like this?
Old Jan 25, 2015 | 12:23 PM
Ghetto Mr Bob's Avatar
Ghetto Mr Bob
Were the bulbs aftermarket? I actually had a pair of aftermarkets partially melt part of the socket from becoming too hot. Now I have to slightly bend the pins on the bulb to make proper contact. Does it flicker if you wiggle it or move the wiring slightly?
Old Jan 25, 2015 | 01:48 PM
jsaum's Avatar
jsaum
Yes, the bulb is aftermarket, however, the bulb works in the passenger side headlamp that is working so it does not appear that it is a bulb issue.
Old Jan 25, 2015 | 01:52 PM
Ghetto Mr Bob
Right, what I'm saying is check the car side of the connection or see if it'll work if you wiggle the wiring.
Also, check the connector (not on the bulb itself, on the car side of the connection) and see if it's maybe charred or dirty.
Old Jan 26, 2015 | 06:23 AM
shreksbrother's Avatar
shreksbrother
I've never had an issue like this, but the first step I would take is to grab a multimeter and check for voltage at the connector. That rule out wriggling the connector or anything. Then start with fuses and work your way around the wiring looking for burned wiring or splices/breaks in it.
Old Nov 13, 2017 | 03:50 AM
NewbieR56's Avatar
NewbieR56
Did you ever find out what your issue was? Having the same problem. Changed out ballasts and bulbs
Bennyboy
Aug 18, 2015 07:28 AM
M1N1M0X1E
Aug 17, 2015 09:01 PM
fm.illuminatus
Aug 10, 2015 12:15 AM
