R56 Yellow emissions light on ODB scanner
Old Jan 2, 2015 | 06:39 PM
mikbau's Avatar
mikbau
Hello all
This afternoon I had the check engine light appear on my 13' R56. I ran an ODB scan on it, and the code was P0128 (Coolant temp too low) - this is the first time I've seen it, and I'm hoping it was a fluke.
I noticed that the emissions light on my scanner (Innova 3100) was Yellow (options are Red, Yellow, Green) - has anyone run a scan where their emissions light came up yellow when there wasn't anything wrong? There aren't any additional codes in the Mini's system indicating there is anything up with the emissions system, and it's persisting yellow on the scanner, even after I cleared the P0128 code.
(Edit: about 47k miles on the car, no other issues thus far. It's currently kept outside, and it's been dipping down in to the mid 20s at night)
Thanks!
Michael
Old Jan 3, 2015 | 08:46 AM
AZdsrt's Avatar
AZdsrt
I would take it to the dealer, you still have warranty left. Coolant running too cool is an emissions related code..
Old Jan 3, 2015 | 09:00 AM
mikbau's Avatar
mikbau
Thanks...unfortunately I'm out of warranty and in hoping to diagnose it myself. What's odd is that the yellow emissions light on the scanner persisted even after I cleared the code
Old Jan 3, 2015 | 09:23 AM
cristo's Avatar
cristo
Alliance Member
I believe the R56 has an electronically controlled thermostat - it might be
either that or the coolant temp sensor, which is attached to the thermostat
housing. You can at least see if the connector to it is attached properly if
you can get to it. I have an R50, so I can't tell you first hand.
Here's a diagram for the R56 Cooper S - the Cooper shows the same part no.:
http://www.realoem.com/bmw/showparts...51&hg=11&fg=35
Old Jan 3, 2015 | 09:47 AM
Slave to Felines's Avatar
Slave to Felines
With a '13, you should still be under warranty. Maybe out of the free maintenance time frame, but still within warranty. Check with the dealer about that if you're unsure.
Old Jan 3, 2015 | 09:50 AM
AZdsrt's Avatar
AZdsrt
Originally Posted by mikbau
Thanks...unfortunately I'm out of warranty and in hoping to diagnose it myself...
A '13 with under 50k miles, should have warranty left..
Old Jan 6, 2015 | 08:48 AM
mikbau's Avatar
mikbau
Thanks all. You're right. I have a couple K before the warranty ends. I've got a call in to a service advisor. It's only thrown the code once, so it's possible it was a fluke
Old Jan 8, 2015 | 10:14 AM
mikbau's Avatar
mikbau
Quick update - it was the temperature sensor that went south...but in giving it a look, the dealer determined the water pump had a leak as well, so they're fixing that now as well.
Thanks for everyone's input - glad I was able to sneak this in right before the warranty expired
~m
danielbrookes_9
Oct 3, 2015 12:51 PM
portedbuckle
Sep 11, 2015 07:02 AM
Lschneider
Aug 21, 2015 02:21 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
jrezzo
Aug 9, 2015 10:32 PM
