R56 Considering a mini: couple questions first...
My advice is to avoid the following:
2007 – 2010 R56 S model (N14 engine)
2009 – 2010 R57 S model convertible (N14 engine)
2008 – 2010 R55 S Clubman (N14 engine)
Also - the JCW used the N14 thru 2012
Problems include: It may drink lots of oil, carbon build-up, fuel pump, and the timing chain.
The timing chain tensioner is under extended warranty by Mini, and it's cheap and easy to replace yourself: it's like a $50 part.
Carbon build up: just redline the car once in a while. People get the S version and drive it like a grandma. A lot of turbo engines will get buildup if you keep the RPM's under 3000 all the time. Also some fuel additive once a month helps.
Fuel pump issues aren't THAT common.
Not sure about "drinking oil". Haven't had experience with that one.
you have to understand one thing though. 95% of the posts are people with issues. People dont post if they dont need help. This is just how it is and will be. Yes the 2nd gen has issues, but i sometimes wonder how many are out there that are problem free and just not on this sight. I will say i had to replace the engine on my car, but i feel like that is my problem. I didnt know the proper care. Now on my second N14 engine, im not burning oil and it feels solid. My A/C works great, but i can and know how to charge it myself. I cannot say that it is not loud though. Overall, i think you should find a mini that you can fall in love with. Something you enjoy. Every model mini has an issue in something or other in my opinion.
Don't know what all the hate is on the R56 N14 Engine. I have a Cooper S convertible that's given me hardly any issues. I've replaced the tensioner and the thermostat. Never had an issue with it consuming oil. Never had an issue with the timing belt/chain. My mechanic says it's in great shape. He specifically works on MINI and BMW.
It's been a reliable car since day one and I'm always in it.. however, I do need to get the intake walnut blasted or whatever every once in a while.
That really really sucks, and I feel bad for you. However, is that the norm though? Are 90% of all Mini's going to have this issue, or 1%?
The build-up/carbon/need for walnut shell has nothing to do with the turbo, it's a byproduct of direct injection, which is superior in every other way. You might not hear about it, but the latest-gen of VAG DI engines, and other makes also require periodic walnut blasting.
Blown motor may not be the norm, but the timing chain is.
I hope you never have to deal with an "oil drinker," it's not fun. I know first-hand what a hassle it is. It's a real problem on some N14 engines; and other N14 engines do not have the problem.
Also, it sounds like you're a good mechanic...$50 to replace a timing chain tensioner. How much do you charge to replace a stretched timing chain? You've gotta be less than the standard - $2,000.
3 pages into the comments, i doubt there will be much useful to add, but here goes. I am on my 3rd MINI (serially). 06 Hardtop, 09 Clubman, 13 Clubman. All normally aspirated, all Manual trans and light exterior colors. very little problems with any of them. 06 broke a rear stabilizer link (warranty fix) later, I slid it into a curb on ice and knocked the front end out of alignment, but did not break anything. align job- my dime. had a black roof and sunroof, black interior. when our kids grew beyond the capacity of the rear seats, we decided on a PW allover for with black roof rails and rear columns for our 09 Clubman. Upstate NY is not Tex or AZ. AC always did the job.
I ran the 09 oil low once, which caused me existential dread, but no failures. Hood release cable fail issue - off warranty- covered at a local import/BMW shop.
Had a warranty repair of driver window motor. otherwise 60 K of trouble free driving.
the CEL came on 2 mos after it was paid off- dec 13- local BMW shop warned of timing chain problems they would not take on My local MINI dealer (3 hr drive) instead diagnosed as only needing new plugs. we loved everything about the car, but I was always gonna worry about when the oil incident would come back to bite me. we traded for a floor model 13 clubman. again light- their white top silver body paint custom edition. all 3 of our MINIs have been dead reliable transportation for 8 years now. if I was worried about AC, I would select a car with light paint color and white roof. then try and find one with the lighter polar white or similar interior colors. as for overall reliability, the base engine is easier to care and feed. no supermodel performance, no supermodel drama. none of these cars will ever be QUIET till there is an integral frame around the door glass. rowing a 6sp and being OK with 2sp downshifts for steep hill climbs at speed is my choice. it is still plenty of fun in the curves. if you need the HP, dont buy a base model.
My summation, a clubman is the perfect previous gen MINI. small enough to be fun tossable driving, big enough to be a primary car for empty nesters or a young couple. I think the Barn door access to cargo area is better than a hatch for tall people. I can carry all the groceries we need back there, maybe fold a seat down sometimes. Roof rails and thule bars allow me to carry bikes, skis, lumber, plumbing pipe. Rear seat access good with clubdoor. headroom back there is good enough for 6+ footers and legroom is ok if 5'9" or under sits up front with the seat pumped up a bit, though not for 3+ hours. Up front, the manually adjustable sport seats are delightful seating for both tall and short. the drivers seat in our "Clubmen" has been the most comfortable for me of any cars I have ever driven. the longer i sit in it, the better it gets. That said, this is not ever gonna be a highway cruiser. the wheelbase is just too short. however, the extra 3 in in WB does settle it down a lot from the twitchier ride of a hardtop when you find yourself on an interstate for 2 hours. check you oil frequently. only 4qt in the base engine. under warranty buy a change at 5k. dont wait for the 10k interval, or buy one that was treated this way. I think MINI realizes this sweetspot since new 4door ccooper looks to be growing to essentially the size of my clubman.
