R56 is it true....
Old Aug 16, 2014 | 12:42 PM
Ex Z3Coupe's Avatar
Ex Z3Coupe
is it true....
...that a Chevy Cobalt compact spare tire will fit my 2012 cooper S ? I want to ditch the run flats .
Old Aug 16, 2014 | 02:00 PM
Btwyx's Avatar
Btwyx
You don't need a spare to get rid of the runflats. At a minimum you need a compressor and a can of slime (not fix-a-flat). Some people also like to have a plug kit or AAA card and cellphone.
Old Aug 16, 2014 | 03:50 PM
bergii's Avatar
bergii
That's what I have.
Old Aug 16, 2014 | 07:20 PM
Ex Z3Coupe's Avatar
Ex Z3Coupe
but...
...but I have a tendency to pick up nails/screws in the edge . I feel better with a spare when I'm 30 miles from the nearest town .
Old Aug 16, 2014 | 08:05 PM
bluefox280's Avatar
bluefox280
Two things that needs to be checked are: OFFSET and HUB BORE.
The Chevrolet Cobalt has two different bolt patterns, a 4x100mm and 5x110mm (5x4.33") lug bolt pattern; the MINI is a 4x100mm.
By the time you search for a working non-MINI spare, you'll still need to put the correct tire on it.
Might as well grab the correct spare wheel from the dealer or MINI parts supplier and slap a correct tire on it.
- Erik
Old Aug 16, 2014 | 09:05 PM
scubbysnacks's Avatar
scubbysnacks
Honda civic 15" space saver from wreckers. If you want to be sure ask if you can test fit it. Job done and money saved!
welcha13
Suspension
Feb 13, 2011 10:49 PM
MiniSprt
Dec 10, 2002 05:42 PM
