R56 Powdercoating some go fast stuff
Old Aug 16, 2014 | 11:03 AM
gzaos's Avatar
gzaos
Hey so here's the deal I work at a wheel powdercoating shop, I've got some extra powder and time on my hands. Planning on shooting the compressor side of my turbo, the heat shield and my K&N typhoon intake tube and air box a blue that matches my car. Anyone had experience shooting a turbo? It's my only concern, how far would I need to tear it down to prevent damage? I've done some research and I'll be using high temp tape to mask off any connectors am internal components. If anyone's had experience chime in, if not I'll upload the results by the end of the weekend. MOTOR ON FRIENDS
Old Aug 16, 2014 | 05:47 PM
gzaos's Avatar
gzaos
Got the intake done didn't tackle the turbo I'll do it when I can afford some ceramic coating to the hot side
Pretty happy with the air box tho!
Old Aug 17, 2014 | 12:04 PM
Porthos's Avatar
Porthos
I would not powder coat the turbo. Not because you will tear it up but, because the heat will just take the powder coating off. I would ceramic coat that. I would like to do that to my turbo since I have already done the heat shield and the down pipe.
As far as tearing it down to get the turbo off, just get a Bentley manual and go into service mode because it is a lot easier. I did a turbo swap without going into service mode and it was a PITA. I could have probably save a couple of hours of work if it was in service mode.
Old Aug 17, 2014 | 12:43 PM
gzaos's Avatar
gzaos
I've read that the compressor side doesn't get above 400f powder bakes that hot, if you have experience trying it tho I may wait and do both with ceramic. I'm gonna go pick up a ceramic gun since we have everything else and I believe it's the same process give or take some temps. My heat shield I'm gonna do white so ceramic would be needed since white would show any burns easily. Should be cool when I'm finished up.
Old Aug 17, 2014 | 01:32 PM
bjcarter2's Avatar
bjcarter2
You shouldn't have any issues using high-heat powder on the cold side of the turbo. Lots of places do it.
Old Aug 17, 2014 | 02:28 PM
Porthos's Avatar
Porthos
But, what a wast of time to do one ceramic and one powder. Just do it all ceramic and call it a day. I know that ceramic coating leaves you with limited choices in color though. I just did my like a semi gloss black because it just looked good. If I do the turbo it will probably end up the same color just because.
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
