R56 Retrofit with F56 style headlight
I realize this is dragging this one back from the dead, but what was the verdict? R56guy, did you use the 'halogen' housing, put a HID kit in it?
If so (seems that way) -- can you confirm the bulb (H9?), the harness setup (which canbus adapters did you use), 35w or 55w ballasts, which bulbs and ballasts?
Inquiring minds...
Inquiring minds...
Think R56guys bought the halogen ones then installed HID retrofit kit ?
ECS, that makes sense -- I found the Spyder ones on your website (2862390) -- and on another website, they have a kit that has HID bulbs, ballast, wiring harness.
I believe the components they put in the headlight capsules are probably not very good. My question is, what are the components to make it work on these cars? My guess is:
H9 HID bulbs
35w ballasts
H13/9008 wiring harness
Canbus adapters (flicker eliminators, whatever)
? anyone?
H9 HID bulbs
35w ballasts
? anyone?
Welcome,
Yea, Halogen spyder projectors then some third party HID kit or something.
PR0-YD-MC07-DRL
ES#2862390
Hopefully R56guy will post up.
PR0-YD-MC07-DRL
ES#2862390
When you get the Spyder Xenon HID DRL kit ( PR0-YD-MC07-HID- ES2863258 ) for your Xenon optioned MINI with headlight washer, you take them out with a couple screws, unplug them and the go right into the new Spyder headlights. Hence the Spyder HID DRLs have cutouts and mounts for the factory Xenon headlight and covers. Then they work just like factory. Of course isf you halogen and go to the halogen Projector DRLs they have dummy chrome covers as the factory halogen headlights have no headlight washer jets.
I hope so ,
The other options fro the R53 R52 R50 are here:
https://www.ecstuning.com/Mini-2005-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Lighting/Headlights/
I've seen those on some R56s on instagram. Seems like a nice piece of kit but I don't know about the light performance or if it's a plug and play or you have to do a bit of modding on the wiring loom so I pass personally. They look great though.
check this set ive never seen before, no washer cut out:
http://www.ebay.com/itm/111939404046...%3AMEBIDX%3AIT
anyone dare to try?
anyone dare to try?
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
