R56 Tuning question
Old Mar 29, 2014 | 07:21 AM
TopLegion's Avatar
TopLegion
Tuning question
I have a 2010 base cooper that I would like to get tuned. All of the out-of-the-box ecu tuners I look at are for the turbocharged s model. Does anyone know of anything I can do?
Old Mar 29, 2014 | 07:47 AM
chrunck's Avatar
chrunck
Buy an S. There really isn't much to be gained on a Cooper.
Old Mar 29, 2014 | 08:09 AM
ra2fanatic's Avatar
ra2fanatic
Battle Tuning can tune your ECU as well...
Old Mar 29, 2014 | 02:41 PM
Slave to Felines's Avatar
Slave to Felines
ECU tuners generally do very little for a non-boosted motor. On most turbocharged cars, they can raise the limit on boost, and make very noticeable gains that way, but that's not an option for our base Coopers.
In general, the factory didn't leave a lot of performance on the table when they built our engines. It is likely that any gains you see would either be very small, or would cut down on the safety margins of your engine and put you at higher risk of engine failure.
If you can upgrade the engine itself--for instance, with a high-flow tuned exhaust system--you can tune the engine management to use that most effectively, and then you may well see decent gains. If you have the head ported, possibly larger valves installed, and/or a cam swap, tuning the engine management is just about mandatory for the new setup to work effectively together.
But if you're not changing anything major, don't bother with the ECU tune on a non-Turbo Cooper.
W0TM8
Dec 19, 2019 07:50 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Emnotek
Aug 13, 2015 05:47 PM
ki7hy
Aug 12, 2015 07:07 PM
papawhiskey
Aug 10, 2015 09:31 PM
