R56 I cannot read the dipstick for the life of me
I have the Cravenspeed dipstick and it is even hard to read in my opinion. So here is how I check the oil. I drive my R56 up on ramps, and I drain the oil into a measuring bucket. Yes, it's a pain in the ****, but I can tell you that I have checked the dipstick, and it looked like my oil level was proper, only to find out I was almost a quart low after draining the oil and measuring it.
Never in my life have I had a problem checking the oil in a vehicle until I acquired a MINI
Xenon6
Not being able to read the oil level was one of the first problems I found when I was buying my used 2008 mini S. To fix this problem, I cut a short piece of yellow 1/4"
heat-shrink tubing (polyolefin) to fit between the high and low area in the cylindrical section of the dipstick, then I set it with my heat gun.
Placing the heat-shrink in this area will not increase the diameter of the dipstick where it has to rub on the tube when pulling it out
or reinserting it. With this yellow section, the oil level is VERY easy to read even when fresh.
I am still having the same issues I had 2 years ago, when I bought the car.
On the one side of the stick, I can see oil ranging from half to full, whereas the opposite side is way lower.
I don't know which is correct and I am putting some oil, just to ensure that both sides are inside the MIN - MAX boundaries.
Crappy system
Crappy system
Crappy system
Crappy system
https://www.cravenspeed.com/return-policy/
People also resell these things on the forums a lot too, but you won't have a warranty.
I am reviving the thread, sorry.
I also had a hard time reading the dipstick. It seems like the workshop which changed the oil prior to my ownership (I hope) had issues with it too, therefore, had put in less than needed. The engine is found to be missing 1 liter of oil after 1500kms of usage. Let's see how it goes.
I have read the dipstick on dozens of cars and never had the confusing readings of my R56 dipstick. FWIW, mine is the little wire type with the red double bulb end.
I’ll try wiping it down and leaving it out for twenty minutes and see if that gives a better reading.
Peter
Peter
Still the readings were so flaky that I bought the Cravenspeed dipstick.
End of story. It works great with ZERO question marks on level.
Sad that what looked like such a great design by BMW was SOOO terribly bad. Oh well. I wonder what the dipsticks look like on Minis that are readable?
Peter
Peter
