R56 Sun visor light?
Old Jan 15, 2014 | 09:58 AM
junkdino's Avatar
junkdino
Sun visor light?
Today I notice the lights in my sun visor on the driver side were out. The passenger side is still working fine. Is there a guide on here to fix it yourself? I looked but couldn't find one. Or would it be easier to just take it to the dealership? Forgot the say I have a MCS 2009
Old Jan 15, 2014 | 01:43 PM
There is a little plug that connects at the end of the visor. make sure it not unplugged a little or somehow was loose first. There are two little screws that hold in the unit to the headliner , then a little plug in socket for the power. Trigger inside the flap ,might be bad also, its wired in. There is no separate part number for the bulbs or trigger.
This is for the R55 and R56 Models up to 8/2010 using Hellgrau or "Gray". In 8/2010+ they went to a beige color and different part number.
Sun Visor / Mirror Illumination Left ( driver side ) - HellGrau
http://www.ecstuning.com/Search/SiteSearch/51167263963/
Sun Visor / Mirror Illumination Right ( passenger side ) - HellGrau
http://www.ecstuning.com/Search/SiteSearch/51167263964/
This is for the R55 and R56 Models with carbon black or anthracite headliner :
Sun Visor / Mirror Illuminated Left - ( driver side ) Carbon Black
http://www.ecstuning.com/Search/SiteSearch/51167322219/
Sun Visor / Mirror Illuminated Right - ( passenger side ) Carbon Black
http://www.ecstuning.com/Search/SiteSearch/51167322220/
Old Jan 16, 2014 | 09:11 AM
junkdino's Avatar
junkdino
I think it is a bit loose. When I moved the visor around the light came on. Thanks for the advice I'll open her up and see what's going on
Old Jan 16, 2014 | 11:03 AM
You are welcome. I remember last time I messed with one, the mirror and trim stuff was bonded on the front and the otter lining is sealed. So I don't know much about taking it apart other the there is a switch with the flap. Check that connection plug also.
Thanks and good luck. You have the part numbers above if nothing else works.
Old Jan 16, 2014 | 01:29 PM
RicWRX's Avatar
RicWRX
How do you change the bulb?
Old Jan 27, 2014 | 02:56 PM
a2oc's Avatar
a2oc
If you are going to remove the mirror only, be careful not to broke the clips as they are quite brittle. Mine just falls off when i was driving it and the lights in it stay on as the mirror thing has something to stick out to push the light switch for the 2 bulbs inside the actual visor. Cost me a new visor because of this. You can actually do it yourself in 5 min. (Remove the 2 screw covers with a knife and 2 screws holding it, REMEMBER to keep those as they arent included in the new visor) (feels much more soild than the original 09 visor) And it looks like all of the new visors got english and french warning on it, instead of english only. Mine is a 09 R56S too
triple5soul
Nov 19, 2019 07:46 AM
WarEagle
R55 :: Clubman Talk (2008+)
May 3, 2019 03:00 AM
gmonde
Sep 8, 2015 06:37 AM
SamtheSham152
Aug 20, 2015 06:01 PM
