R56 warning Light
Old Jun 18, 2013 | 02:51 PM
jordan.burks's Avatar
jordan.burks
warning Light
So i have been reading threads on maintance for the r56 MCS and i think i have a pretty good grasp of what is to be done and when but i wanted to make sure. I have about 53000 miles on my 07 and my warning light with the mini on a lift says i have a few thousand miles until its due. now i have had all the fluids changed, the belt changed, the filters changed and the spark plugs done. is there anything i am missing? since all of that is done do i need to take my car in for service when the light hits the mileage or can i just reset it now?
Old Jun 19, 2013 | 08:17 PM
afadeev's Avatar
afadeev
All you need to do is reset your service intervals.
Really easy:
a
Old Jun 19, 2013 | 08:36 PM
jordan.burks
Thanks man, i actually know how to reset the light. I was just wanting to know if there was anything else besides the things i listed above that needed to be serviced when the light came on. or what all does that light indicate needs to be done? thank you anyway though!
Old Jun 19, 2013 | 08:44 PM
afadeev's Avatar
afadeev
Mini Maintenance Services
Mini Coopers have 3 types of service: Oil Change, Inspection 1, and Inspection 2. Your Service interval display located in the center of the speedometer will notify you of which service type you need. Each time the vehicle is started the display will show the mileage until the next service is needed.
If the display is flashing and the mileage is displayed as a negative you have gone past the time of service and are overdue. The services come in this order, Oil change, Service 1, Oil Change, Service 2. repeat. Service 1 is also known as a Minor service and service 2 is also known as a Major service.
Oil Change
This service changes the oil and oil filter. It also includes: inspecting Brakes, Parking Brake, Fluid levels, Tire Condition and Air Pressure.
Inspection 1 (Minor service)
Includes services in Oil Change (above) plus: change Interior Ventilation Filter, change Transmission fluid if CVT, add Windshield Washer fluid, check Wipers and Washers, lubricate doors and locks, check Battery condition, Suspension, CV boots, Exhaust System, Manual Transmission fluid level, pressure check Cooling System, and reset Service Indicator and road test for overall performance.
Inspection 2 (Major service)
Includes services from Oil Change and Inspection 1 plus: change Air Filter, Engine Coolant, flush Brake fluid, and mileage. Model dependent add on's include: Spark Plugs (100K), Belt change (100k cooper 60K S) and Oxygen Sensor (100K).
a
P.S.: Source: http://www.pearceautotech.com/articl...aintenance.htm
Old Jun 19, 2013 | 09:01 PM
jordan.burks
thank you! that is what i wanted to know.
Old Jun 19, 2013 | 09:23 PM
jordan.burks
100 thousand seems like a long time for spark plugs. i just did mine at 52500 and they were already fouled and the gap was huge.
bneer
Jul 15, 2019 04:41 PM
Lschneider
Aug 21, 2015 02:21 AM
one73ronin
Aug 19, 2015 12:36 PM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
