R56 Odd no start issue
Old Jun 6, 2013 | 06:04 PM
ojannen's Avatar
ojannen
Odd no start issue
I just drove home from work in my mini cooper s with no problems. It sat for about 30 minutes and when I went to start it to run some errands I got a bunch of error lights. The check engine light and orange brake light are on. A brake wear sensor warning is also up. The brakes are not due for a change for about another 5-10 thousand miles.
When I try to start the car it will not crank. I am getting no noise at all. I don't have a code reader here so I don't have any code information right now. Does this series of errors ring a bell for anyone?
It is raining pretty hard here in central Florida with the tropical storm passing us by. My current guess is that some water got into the engine bay and is shorting something out.
Thanks for any help you can give me.
Old Jun 6, 2013 | 06:41 PM
Braminator's Avatar
Braminator
Where are you located? Maybe another member close to you has a scanner.
Old Jun 7, 2013 | 12:43 AM
Minicoopr50's Avatar
Minicoopr50
This happened to me before, check the sensor on your clutch. It easily comes detached.
-dylan
Old Jun 7, 2013 | 08:43 AM
Velocityvic's Avatar
Velocityvic
A weak battery cause modern electronics to go crazy. You could have a shorted or dead cell. Check your battery.
Old Jun 11, 2013 | 03:50 PM
ojannen's Avatar
ojannen
Just got it back from the repair shop. The starter motor was completely dead. Unplugging the battery removed the brake and brake wear warning lights and they did not come back. The guy at the shop said this was very rare.
This car has had a pretty ridiculous repair record including both fuel pumps, clutch, and timing chain. Maybe I just have a lemon.
Old Jun 11, 2013 | 08:23 PM
Velocityvic
From what I've gathered a starter isn't one of the more common problems. (cross my fingers.) What's a starter cost?
Old Jun 12, 2013 | 04:12 AM
ojannen's Avatar
ojannen
Roughly $350 for the part and $150 for the install.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Teh
Jun 13, 2018 02:59 PM
theblackfalcon
Oct 11, 2015 09:49 AM
veevsato
Aug 5, 2015 04:42 AM
