R56 License Plate Bulbs Out
Old Apr 15, 2013 | 08:35 PM
aerojt's Avatar
aerojt
Had the dash indicator tell me a light was out on the mini. Traced it to the license plate bulbs. I opened up the covers, both bulbs look fine, but they don't come on.
Fuse? Ground? Any ideas? I'm kind of in need of some help here, don't want a ticket for this. I'm guessing a ground of wiring issue since they are both out. I've read it can be a fuse because all the other lights work fine. Is there a ground strap somewhere around there?
Thanks for any help you can offer.
Old Apr 15, 2013 | 08:46 PM
highlander709's Avatar
highlander709
Try replacing the bulbs anyway - they're cheap. I had a similar problem and replacing with new bulbs solved the problem. I believe this is a fairly common issue.
Old Apr 15, 2013 | 08:47 PM
aerojt's Avatar
aerojt
Both went out simultaneously? Thanks for your help, I'll be changing them tomorrow. Then we will see what happens....
Old Apr 16, 2013 | 12:04 AM
Systemlord's Avatar
Systemlord
I also have a running light go out on the front lower left, before I got to the local autoparts store it started working again! Maybe the bulbs filament has not fully gone out yet, we'll see!
Old Apr 17, 2013 | 06:54 PM
aerojt's Avatar
aerojt
Just changed the bulbs, all is well. I have no idea how/why they both went out at the same time... But $6 later and we are legal again. Thanks for the advice and help.
JHolland
Sep 24, 2020 08:20 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
n0mis
MINI5280
11
Mar 9, 2016 05:04 PM
ericf1993
Sep 26, 2015 03:58 PM
