How do I remove the water tube?
Old 01-25-2016, 11:21 AM
ECSTuning is online now
Received 1,967 Likes on 1,767 Posts
Yea, That smoke if you reeving the engine and then putting it into drive possibly on the transmission. I would stop doing that all together till you figure out was going on . The Oil leak at the front would be easily seen need the turbo.
You need to dig into that shiftier section.
For the oil line and oil filter housing leak.
https://www.northamericanmotoring.co...leak-pics.html
  #77
Old 01-30-2016, 06:57 PM
[My_Mini]'s Avatar
[My_Mini]
[My_Mini] is offline
Welcome.
The engine will serge down hair when you switch from neutral to drive, and you will feel the engine move a bit and from drive to reverse. How much it is moving, thats the question.. A lower engine mount that is bad can cause the engine to move around in the engine bay more.
https://www.northamericanmotoring.co...ference-2.html
So took me a while to figure this out but I took it to a local mechanic, and it looks like it will be the engine not being well sustained. so this engine mount you mentioned should do the trick?
  #78
Old 04-12-2016, 05:18 AM
Johnd214's Avatar
Johnd214
Johnd214 is offline
Hi im new to this forum.
After replacing the thermostat housing i got the same p0706 code, did the engine mount fix your problem?
  #79
Old 01-18-2018, 10:50 PM
OldHoopsJunkie's Avatar
OldHoopsJunkie
OldHoopsJunkie is offline
This is just plain wrong, at least with respect to my 2009 Cooper S:
There should not be any wire unless you moved the pipe and bumped some of the wire under the intake manifold.
The coolant pipe had a wiring harness attached to the tab in the middle. Used a hammer and big screwdriver to knock the harness off the tab.
One of the tabs closer to the end also got caught on some wiring. It was easy to move the wiring out of the way once I could find it between openings in the intake manifold.
  #80
Old 01-19-2018, 09:35 PM
OldHoopsJunkie
Obviously you don't like being contradicted by your elders, but:
Mine had wires attached in a small wire harness to the middle tab. I used a hammer and big screwdriver to drive that small harness out by breaking the tab.
So, obviously, on some Minis, there are wires attached to one of the tabs.
I posted a similar note last night, and I see that it was deleted.
I shop at ECS Tuning. If you're trying to convince me not to shop there anymore, have this one deleted.
WarEagle
R55 :: Clubman Talk (2008+)
05-03-2019 03:00 AM
ltjpunk7
09-06-2015 07:32 AM
patsum
08-26-2015 06:29 AM
greekzilla
08-23-2015 03:44 PM
Getrieben
08-15-2015 09:09 PM
Quick Reply: How do I remove the water tube?
