R56 The Mystery of the Torque Arm Insert Dispelled
Old Oct 15, 2014 | 07:03 PM
  #26
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Originally Posted by kaikai114
I have the 2012 Countryman S FWD auto tran, and whenever I floor the gas pedal the front wheel hops like mad, will this reduce the torque steer even on the automatic transmission? since the insert is to stabilize the engine, I am guessing it works just the same on the auto trannie.
Kevin
Yes it works the same on your countryman and is really a great mod for the money.
If you need one we keep them in stock
http://www.waymotorworks.com/nm-engi...t-r60-fwd.html
Old Oct 15, 2014 | 07:55 PM
  #27
kaikai114's Avatar
kaikai114
Placed the order yesterday hope to get it asap
Old Jan 11, 2017 | 11:38 AM
  #28
miniuy's Avatar
miniuy
Order done!
I will let you know about running this arm inserts on a Mini 2010 Base.
Old Jun 12, 2017 | 08:09 AM
  #29
miniuy's Avatar
miniuy
I have installed the NM arm insert last weekend and I can't feel any great improvement as I could read here.
May be because there is a lot of vibration at neutral/idle (800RPM) in the pedals and footwell (I have a manual and I can feel the vibration on the 3 pedals plus the floor) and I'm just paying attention to that.
There is not any vibration at all when launching, accelerating nor driving (city/highway).
The arm insert was properly installed (flexible parts installed without problems and checked, and the small metal retain bracket installed with the original bolt as in the instructions pictures). The re torque the bolt to the the spec (108Nm).
Since it's a flexible material I hope there is a "time" to get the car to be quite as soon as it is used.
If not, I will be removing the inserts.
There is any advice or any additional step missed to remove the vibration?
Old Jul 14, 2017 | 12:00 PM
  #30
miniuy's Avatar
miniuy
More than 1 month and the vibration is still there.
I was thinking on increase the idle RPM value from 750 to 800/900, where the vibration is not present at all...
Old Jul 18, 2017 | 09:46 PM
  #31
Gubi's Avatar
Gubi
I had mine in for a year and it still vibrated noticeably at idle. Finally got annoyed enough and just took it out.
Old Jul 20, 2017 | 06:29 AM
  #32
miniuy's Avatar
miniuy
I thought the vibration was reduced, but yesterday a friend was driving the car and asked me "why do your footwell vibrate in this way???".
My feet are getting accustomed, but the vibration continues.
I'm going to wait a few months and if I can not find a definitive solution, I'll uninstall them.
Thank you for your comment.
Old Jul 22, 2017 | 07:04 AM
  #33
jackski2's Avatar
jackski2
I put in the PowerFlex Race bushing last year. It did quicken up throttle response noticeably but I have a Manic tune also and it accentuates any changes. Shifting was also just slightly crisper especially when going over bumps, but it was again not a huge change.
Vibration is up. It's acceptable to me in the summer. In the winter it all stiffens up and would likely be offensive to some.
I'm going to put in the front PowerFlex bushing soon and see what happens.
Old Jul 24, 2017 | 07:12 AM
  #34
miniuy's Avatar
miniuy
PowerFlex Race (harder) seems to generate a lot of vibration more than "normal" PowerFlex.
In my case I have the NM, which supposedly generate less vibration than "normal" PowerFlex.
Clearly, I have not been lucky...
Lex2008
How to
47
Jun 15, 2022 06:18 AM
bahman
Nov 15, 2019 05:45 AM
hydouken
Sep 15, 2015 05:49 AM
Suspension Products
Sep 10, 2015 11:46 AM
Sep 3, 2015 12:24 PM
