R56 What is knock?
Old Apr 16, 2012 | 03:32 PM
Powashiftin's Avatar
Powashiftin
What is knock?
Under acceleration sometimes my car sputters for a second, I hear a rattle and then it kicks back in. Is that knock or knocking?
Old Apr 16, 2012 | 06:46 PM
bluefox280's Avatar
bluefox280
Engine "knock" (or auto-ignition) is when the air/fuel mixture inside the combustion chamber combusts before the spark plug is supposed to fire.
The 'pinging' noise you hear is the explosion of the fuel mixture being compressed by the piston when the cylinder is still traveling to top-dead center on the compression stroke.
If you're getting a rattle that's similar to what I described above, it could be auto-ignition issues.
However, a rattle (metallic in nature) sounds more like a possible timing chain issue.
First, are you using the proper grade of premium fuel in your turbocharged S-model?
Have you ever had issues in the past with sputtering or hesitation?
- Erik
Old Apr 16, 2012 | 07:05 PM
mrhumph's Avatar
mrhumph
shake a can of gravel.
I don't know why the call it ping. If the sound is like a tin can with a few stones in it rattling then its knock, ping, pre-ignition.
If there is hesitation then its timing. Maybe bad fuel. Maybe vacuum leak. Maybe something else.
First dose with some kind of cleaner. then go out and do 5 or 10 WOT runs to hopefully burn out what is in there. Extra carbon can cause pre-ignition.
They call it an Italian tune up.
If anything weird or scary happens go to the service mother and have it looked at.
Cheers.
Old Apr 17, 2012 | 03:43 PM
Powashiftin
- Erik
No real sputtering or hesitation issues in the past~ just this and this has happened a few times recently. And I use premium gas.
Powashiftin
Cheers.
What kind of cleaner?
riff42
Sep 22, 2015 03:07 PM
NeonLed
Sep 15, 2015 02:48 PM
weaver9000
Sep 14, 2015 05:48 PM
tylewis
Sep 6, 2015 01:07 PM
MasterShaftner
Sep 4, 2015 03:52 PM
