R56 Doing first auto cross!!,
Old May 18, 2012 | 08:18 AM
  #51
asujosh1's Avatar
asujosh1
Does changing out the bump stops remove you from the stock class? or could you modify the stock bump stops and still stay in stock?
Old May 18, 2012 | 04:16 PM
  #52
Mini2na's Avatar
Mini2na
You can legally change out the bumpstops and stay stock. That's what I did. You can change out shocks, if you have the $$ too and stay in stock class.
The changeout of the bumpstops was the best $90 ever spent (plus an alignment)
Old May 19, 2012 | 10:16 PM
  #53
cmt52663's Avatar
cmt52663
From the 2012 SCCA Solo Rules - Stock Class - Section 13.5.D
"A suspension bump stop is considered to be performing the function
of a spring. Therefore, the compressed length of the shock at the
initial point of contact with the bump stop may not be increased from
the standard part, although the bump stop may be shortened for the
purpose of installing non-standard shocks. Bump stops installed externally
and concentric with the shaft of a shock may be drilled out to
fit a larger diameter shock shaft. Bump stops may be substituted for
the purposes of installing non-standard shocks."
Old May 20, 2012 | 06:12 AM
  #54
archdukeferdinand's Avatar
archdukeferdinand
Originally Posted by jasyatz
On my SS+ car, I performed the Zip Tie test and sure enough, it's on the top of the shock even after a run...Interested to see if that's the case with the JCW stuff..
Now thats the sort of testing I can get behind. In that case, perhaps we should be exploring bump stop materials. The "bumpstops may be substituted..." rule that Charlie posted seems like it gives one quite a bit of leeway.
Old May 20, 2012 | 10:08 AM
  #55
honda93's Avatar
honda93
Nick,
I sent you a PM.
Keet
Suspension
Aug 30, 2016 03:46 PM
vulkandino
Oct 31, 2015 08:29 PM
cub4bearindiana
Oct 2, 2015 09:45 AM
Oct 1, 2015 12:13 PM
kevinlhr310
Sep 27, 2015 02:31 PM
