R56 Help me!! It's really urgent.
Old Mar 1, 2012 | 04:00 PM
  #26
Porthos's Avatar
Porthos
When was the last time you changed your plugs?
Old Mar 1, 2012 | 04:05 PM
  #27
Scooter162's Avatar
Scooter162
last summer plugs and coils replaced at about 52,000miles
Old Mar 1, 2012 | 04:46 PM
  #28
Porthos's Avatar
Porthos
Hmm thats weird. Might have gone bad. Well keep us posted.
Old Mar 5, 2012 | 12:00 PM
  #29
Scooter162's Avatar
Scooter162
Dealer just called, turns out it was a timing chain tensioner, Kinda suspected that. He told me that it was from dirty oil. I changed the oil last nov. and have not driven it much this winter. Also tensioner was changed last march. I am going to bring that up when I pick it up.
Old Mar 5, 2012 | 12:49 PM
  #30
drsimmons's Avatar
drsimmons
Still don't know why the tensioner would cause it to sporatically start or not unless there are teeth missing on the gears.
You mentioned the timing chain issue was fixed last March. Did they replace everything or just the adjusting bolt?
If just the adjusting bolt that would explain why it failed again.
Is this a Mini dealership working on your car?
Old Mar 5, 2012 | 04:06 PM
  #31
Scooter162's Avatar
Scooter162
Yes, Mini of Omaha, They covered the repair due to the tensioner being replaced last spring. I went to get it, and it wasn't done. it was still showing misfires. The tech was telling me that Mini is having them change the HPFP. I should be able to pick it up tomorrow. This is also covered under warrenty.
Old Mar 5, 2012 | 04:19 PM
  #32
drsimmons's Avatar
drsimmons
I mentioned it earlier, I used to live in Omaha. Worked at First Data Corp. for 20 yrs. Moved down here in 2002.
Anyway, good deal on the fix. The HPFP has an extended warranty of 10yr. 100K miles. I've never had a problem with mine (knock on wood),
Hopefully, everything will get ironed out and you'll be good to go.
chrunck
R60/61 Cooper S Drivetrain
17
May 12, 2014 03:29 PM
sprp85
Aug 15, 2013 06:23 PM
ChristieY
May 19, 2011 09:07 AM
TyCrox07
Jun 28, 2010 07:55 PM
