R56 How to remove R56 Driving Lamps?
Old Feb 18, 2012 | 02:44 PM
gallopingford's Avatar
gallopingford
We plan on pulling the driving lamps off the car - they were installed from the factory so we are curious to know how hard it is to remove the whole system. Any links or writeups would be appreciated. Thanks.
Old Feb 18, 2012 | 07:56 PM
bluefox280's Avatar
bluefox280
I just did this middle of last year.
Are you looking to remove the wiring as well that attached to the foot-well module (FRM)?
The lights, brackets and connections are pretty self explanatory; simply unbolt from the front end fascia assembly.
You will need a replacement grill that has not been cut for the backets.
If you're looking to remove the wiring, you will need to make a few cuts to remove connectors as they do not pass through the firewall.
Also, you will need a replacement knee bump guard that doesn't have the light switch.
- Erik
Old Feb 18, 2012 | 08:18 PM
RJKimbell's Avatar
RJKimbell
From someone who is wanting to have those installed, do you mind me asking why you are wanting to remove them?
Old Feb 21, 2012 | 04:03 PM
jonprivate's Avatar
jonprivate
What are you going to do with the units you remove? I am in need of the front passenger side lamp. I just bought a car and the lady hit a jackrabbit and took the lamp and part of the bumper out.... ouch...
Old Feb 21, 2012 | 07:36 PM
OaklandMini's Avatar
OaklandMini
The easiest way is to simply put the plastic covers over them and never turn them on. :D
Old Feb 23, 2012 | 09:40 PM
Minidrivr's Avatar
Minidrivr
This might help.
https://www.northamericanmotoring.co...aux_lights.pdf
Old Feb 24, 2012 | 07:25 AM
Digitys's Avatar
Digitys
I will buy the set up from you once you remove it! Let me know!
Zettinger
Aug 25, 2015 04:04 PM
JamJam43087
Aug 16, 2015 02:02 PM
DWooderson
Aug 10, 2015 09:12 AM
