R56 help! Carbon build up issue
Old Dec 19, 2011 | 07:21 AM
  #76
etalj's Avatar
etalj
Will definitely do. I have one contact with a 2011 Cooper S. He's not big on modding, so I won't suggest a WMI kit, but I will get him to buy one of my catch cans, and I'll report on that.
You're more than welcome, any time.
Old Dec 19, 2011 | 07:47 AM
  #77
muzak's Avatar
muzak
I'm intrigued about the WMI Kits. Thanks for the links and info!
Old Dec 19, 2011 | 07:56 AM
  #78
Slave to Felines's Avatar
Slave to Felines
Most of the references I see for carbon build-up are for the MCS. Does anyone know if the Justa suffers from the same tendency for build-up?
Old Dec 19, 2011 | 08:09 AM
  #79
SMOG's Avatar
SMOG
Alliance Member
If I were to guess I would say yes, but not to the same extent. It is a direct inject engine but does not have the heat buildup that the turbo gets. A SeaFoam treatment might do the trick if you can figure out how to get the stuff into the system on the 2011 refresh engine.
Old Dec 19, 2011 | 08:12 AM
  #80
etalj's Avatar
etalj
You're very welcome. If you would like any other info, feel free to email me at rennsportracing@gmail.com
For me, if I had my time again, would have been the very first mod I ever did. And I don't do heaps of engine mods, I'm more of a suspension guy.
Old Dec 19, 2011 | 08:38 AM
  #81
muzak's Avatar
muzak
Will do. What level of experience would you say is needed to install a kit? I need to do some homework. Seems like a big investment, but could pay for itself if you keep the car for the long haul.
Old Dec 19, 2011 | 08:56 AM
  #82
SMOG's Avatar
SMOG
Alliance Member
Check out this and other Forums about what to encounter. Seems to me that installing the jet initially and then figuring out what jet is best are the hardest parts of the install.
Fortunately Howerton Engineering is in an annual migration path for me and I might just pay him or someone else, like RMW(good Forum) to install the unit
Old Dec 19, 2011 | 06:41 PM
  #83
etalj's Avatar
etalj
It is a significant investment, and something I would do if I didn't plan on selling the car in the near future.
You don't need much experience to install it, but it is a lengthy install process. Maybe a full day's work. I did mine over two days, maybe 4 hours on one day and 6 on the other. Unlike many things I've done with my R56, I didn't run into any issues.
It's not hard to install the jets, but great care should be taken to be accurate, that's all.
As SMOG said, Jeff Howerton is a great help. Very patient. Also the RMW forums are full of people that have a lot of knowledge regarding the kit.
Old Jan 18, 2012 | 11:19 AM
  #84
second to none's Avatar
second to none
The R56 N12 engine is not direct injected, and wouldnt suffer from this issue. I think the N16 is, but that would need to be confirmed.
Old Jun 15, 2013 | 06:10 PM
  #85
miniMooji's Avatar
miniMooji
Originally Posted by AustinS
The only way to know if a dealer will take care of it is to call and ask.
Another thing you can do is run Seafoam through it and then go out and burn the gunk out of it. Your problem may be that you drive like an old lady.
You need to put some hard fast miles at high RPM's on it. Remember, the best shift point is at the red line!!![/QUOTE]
Well, I'm an old lady and I naturally drive fast, say about 85mph on the freeway, if no cop around. But are you really serious regarding the redline?
Old Jun 16, 2013 | 05:14 PM
  #86
07_JCW_MINI's Avatar
07_JCW_MINI
Along with walnut blasting the valves is the ECU upgrade/re-flash really necessary?
arf88
May 31, 2016 03:07 PM
marendt428
Feb 25, 2016 07:13 AM
eatsleepautox
Oct 30, 2015 06:46 AM
Zettinger
Aug 25, 2015 04:04 PM
marendt428
Aug 9, 2015 06:54 PM
