R56 help! Carbon build up issue
Old Dec 17, 2011 | 06:49 AM
  #51
Juppers's Avatar
Juppers
Originally Posted by Pinky Demon
None taken. As your RPMs increase and your engine has to work harder and faster, it gets hotter and opens your valves up that many times more per second. This tends to heat them up, knock them around a little, gets them moving, and cleans some carbon off. Is it a cure all? No, but it does not hurt either.
That only helps for carbon that is built up in the path of the valves. Any RPM will do that. The problem is the carbon that builds up in the well surrounding the valves that restricts air flow. Heated oil is what creates it. More heated oil does not correct it, quite the opposite.
Old Dec 17, 2011 | 05:01 PM
  #52
masternut's Avatar
masternut
Have they done any improvements to stop this in the 2011 or 2012 MCS?
Old Dec 18, 2011 | 10:24 AM
  #53
SMOG's Avatar
SMOG
Alliance Member
Walnut shell blasting....
Does the 2011 & 2012 need it, who knows!?!
Old Dec 18, 2011 | 06:31 PM
  #54
etalj's Avatar
etalj
I know that Water/Meth prevents it, but soon I will be removing the inlet manifold to see if it actually removes any.
I'm excited to see if it has made a difference.
Old Dec 18, 2011 | 08:46 PM
  #55
SMOG's Avatar
SMOG
Alliance Member
Water/meth does work and IF warranty is not an issue AND you can get the consumables AND KEEP THEM ON HAND FOR LONG TRIPS it sounds like the ticket. For the Track it is wonderful. For around town, wonderful but for long road trips how much meth can you carry??? How many miles per tank of meth at freeway speeds???
Let us know if it really works!!!
What year MINI are you driving??
Old Dec 18, 2011 | 11:35 PM
  #56
etalj's Avatar
etalj
Oh I know that it works, but I want to know if it can actually reduce existing buildup.
You don't need to keep the consumables, you can turn the threshold up, or you can stay under the threshold, you can run a small jet, you can even run straight water if you run out, or you can get the double-capacity race tank.
Freeway speeds under low load, won't use a thing, unless you turn the threshold down.
My water/meth tank (double capacity) lasts well over two tanks of fuel, and my threshold is down, and I run a big jet.
I will definitely let you all now if there's a difference. My MINI is an 08/08 f-JCW (or in US-speak, an 09 f-JCW)
Old Dec 19, 2011 | 04:36 AM
  #57
SMOG's Avatar
SMOG
Alliance Member
Wow! Very good info on that rate of consumption It puts the idea closer to the front of my list than I thought
What water/meth kit are you using??? I was toying with the idea of an Aquamist system.
Old Dec 19, 2011 | 05:30 AM
  #58
etalj's Avatar
etalj
I bought (and sell) the Howerton Engineering HFS-3 (which is basically an aquamist system with a couple changes). I really did my research with that, as it wasn't a small investment.
Yeah, you can set up the system to barely use anything.
BTW, don't know if you've seen this, but it makes for good reading if you need convincing. http://howertonengineering.com/mini/ (read the part where it says R56 dyno graph)
Old Dec 19, 2011 | 05:39 AM
  #59
JPMM's Avatar
JPMM
on long trips use windsheld washer fliud
on long trips use windsheld washer fluid
Old Dec 19, 2011 | 05:46 AM
  #60
SMOG's Avatar
SMOG
Alliance Member
That was the unit that I was considering. Did you sell yours?
JPMM: Windshield Washer Fluid!!!???
Old Dec 19, 2011 | 05:56 AM
  #61
JPMM's Avatar
JPMM
alcohol and distilled water
Old Dec 19, 2011 | 06:01 AM
  #62
SMOG's Avatar
SMOG
Alliance Member
That makes sense. I was thinking soapy water!!!
Isopropyl 99% ???
Old Dec 19, 2011 | 06:25 AM
  #63
etalj's Avatar
etalj
Oh no, I haven't sold mine. I run a company called RennSport Racing down here in Australia. I have fitted three kits: my car, my brother's car, my business partner's Golf GTI (Rabbit Mk5). We are about to install a fourth kit into a ford focus ST/XR5 Turbo
I have also sold a kit to another JCW owner who is yet to fit it.
Don't run isopropyl alcohol. Richard Lamb of Aquamist doesn't recommend it.
You can bring an additional container of water/meth with you, nothing wrong with that, but I honestly don't think you'll need it, as you won't use anything on low load, long distance driving.
Windshield washer fluid is usually meth and water, but they tend to use dyes and detergents that you don't really want running through the pump. 99.9% pure meth and distilled water is ideal.
Old Dec 19, 2011 | 06:38 AM
  #64
SMOG's Avatar
SMOG
Alliance Member
I understand now, thanks.
Yes, as pure a mixture as possible.
Did you locate the Tank in the boot and run the lines forward to the jets and controller?
Direct Injection really caused a big problem for those of us who care!! Audi/VW, anyone who has D.I. can count on a carbon buildup on their valve stems and cold side of the ports and as was said earlier a good Oil Catch Can will help.
What cans are people using? Trying to locate a can in the engine bay is pretty challenging!
The 2011 refresh engine has only 1 hose on the valve cover and it runs to the turbo so BMW?MINI did something different. I am very curious as to what the valves look like after 10K miles or so.
Old Dec 19, 2011 | 06:40 AM
  #65
JPMM's Avatar
JPMM
I have an Auqamist on my turbo bike and I thought I read that windshield washer fluid was OK? I'll see what I can find
Old Dec 19, 2011 | 06:42 AM
  #66
etalj's Avatar
etalj
Sorry, I didn't mean it to sound as if windshield washer fluid is bad. But if you can get one that has a few additives as possible, that's better.
Isopropyl is no good.
Old Dec 19, 2011 | 06:45 AM
  #67
SMOG's Avatar
SMOG
Alliance Member
What type of alcohol are they using if not using methanol?
A turbo bike? Just sounds fast without knowing anything about it
Old Dec 19, 2011 | 06:48 AM
  #68
etalj's Avatar
etalj
Yes, the tank is in the boot, and the fluid line runs through the boot floor, under the car (along the fuel lines) and up into the engine bay. The electrical wiring runs under the interior trim.
I have the BSH can currently, but I'm working in conjunction with Czar to get him to make a catch can with a coalescing filtration medium, and a correctly engineered can that matches the flow rate of the PCV system.
An interesting fact: Lexus apparently has a secondary fuel injector in the inlet manifold that sprays intermittently, purely for the purposes of stopping carbon buildup.
Old Dec 19, 2011 | 06:54 AM
  #69
SMOG's Avatar
SMOG
Alliance Member
Interesting about the coalescing can. I saw something about it in another Thread. Keeping the oil out of that area is a good idea!
The Lexus but not the Toyota??
In Australia do you have to run unleaded fuel? What is the octane?
Old Dec 19, 2011 | 06:59 AM
  #70
etalj's Avatar
etalj
Yes, we do have to run unleaded fuel. We have a choice between 91, 95 and 98 RON (which is not the same octane rating system you guys use, I think you use AKI). I think that'd be equivalent to your 87, 91 and 93 respectively.
I'm not sure if Toyota use direct injection on any models, but I'm sure if they do, they'd probably use the same system.
Keeping oil out of the intake tract is indeed a great idea
Old Dec 19, 2011 | 07:01 AM
  #71
SMOG's Avatar
SMOG
Alliance Member
It sounds like a real lock step movement in fuels! Are you being forced to use 10% ethanhol with talk of raising it to 15%???
Old Dec 19, 2011 | 07:06 AM
  #72
etalj's Avatar
etalj
We do have a choice of E10 (10% ethanol) in quite a few places, and E85 (85% ethanol) in very few places, and I'm not sure if we'll be going up to E15, but I'm sure we will.
At one stage we had the option of 98 RON + Ethanol, which equated to 100 RON
Old Dec 19, 2011 | 07:12 AM
  #73
SMOG's Avatar
SMOG
Alliance Member
Do you guys use corn for the ethanol? Just doesn't seem right to use food to put into a car....
The percentages are the same here with the farmers being a big lobby to use their product as opposed to another source of ethanol.
Old Dec 19, 2011 | 07:15 AM
  #74
etalj's Avatar
etalj
I would say that the majority of our ethanol would come from sugar cane. You guys farm a lot more corn than we do, we're big on sugar cane production here lol
Old Dec 19, 2011 | 07:19 AM
  #75
SMOG's Avatar
SMOG
Alliance Member
I suppose that makes sense being as you are more tropically located.
Keep us Posted as to the 2011+ engines look after a few thousand miles get put on them, if you see any of them in for work.
Thanks for the info!
Stephen
