R56 hood scoop??
Old Sep 13, 2011 | 04:37 PM
JaysR56's Avatar
JaysR56
hood scoop??
why do the sports have them if they are not functional?
Old Sep 13, 2011 | 05:08 PM
MI MINI S's Avatar
MI MINI S
1st gen R53's scoop is functional...second gen R56's scoop is...sort of functional in the '08 and later cars. Lot's of cars have nonfunctional scoops... just eye candy.
Old Sep 13, 2011 | 05:13 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
First and foremost, probably cosmetic to distiguish it from a JAC. And while it doesn't provide the same function as in the 1st Gen MINI's, it is in close proximity to the Turbo providing some venting of trapped heat and induction of cooler air while on the road.
Lots of 2nd Gen owners have been dremeling the scoops fake vent areas to provide added flow. Some have even removed the grille all together....
Old Sep 13, 2011 | 06:30 PM
JaysR56's Avatar
JaysR56
if i get the carbon fiber scoop can i just leave the hole open? my question is if im driving in heavy rain can that do some damage sucking in water over the engine?
Old Sep 13, 2011 | 06:36 PM
-=gRaY rAvEn=-
Moderator
MINI techs use engine degreaser and a water hose when cleaning the R56 engine bay...it doesn't get any wetter than that
Seems to me the screen is mostly there for those larger objects like leaves and cigarette butts, and not so much rain water while driving.....
Those who have taken the time to do so have logged lower under bonnet temps with this mod.
Old Sep 13, 2011 | 07:44 PM
Melangell's Avatar
Melangell
MiniFini Black Intake Scoop Grill...
http://www.minifini.com/ShopDetail.aspx?id=64
Old Sep 14, 2011 | 10:08 AM
cschues80's Avatar
cschues80
The minis that are supercharged have a top mount intercooler. 02-06 MCS came with a supercharger so they added the hoodscoop for air flow. the r56 mCS have turbos but i believe the convertibles still have a supercharger and still run a top mount intercooler. but yes it is just eye candy but apperently it still cools down the motor a good amount if you dremel out the holes that are filled...or jsut get a performance one, Depends if you want to spend the money or not
Old Sep 14, 2011 | 08:16 PM
Melangell's Avatar
Melangell
The stock plug to the hood scoop is almost 2 inches thick. Dremel out the holes all you want, you won't get that much air through to the engine... If you truly want air and no bugs/rocks/etc...
Trust me, DoS CAI, Forge Intercooler, Alta BoV spring, NM heat shield... MiniFini Black Intake Scoop Grill.
Old Sep 14, 2011 | 08:28 PM
Scooter09's Avatar
Scooter09
... not true...
I just ground my scoop grill from the back, I didn't have to dremel each individual hole and it still looks great. Plus, all the holes are opened up and I didn't have to by a new grill.
Old Sep 14, 2011 | 09:20 PM
DneprDave's Avatar
DneprDave
Two inches thick!? I don't think you've actually had the grill out of the scoop and seen it!
Dave
Old Sep 15, 2011 | 06:39 AM
Porthos's Avatar
Porthos
The last convertible to run the s/c was the 08s. 09 and newer run the turbo motor.
Old Sep 17, 2011 | 06:41 PM
Melangell's Avatar
Melangell
Dave
Okay, almost an inch and a half... It's sitting just inside my front door and a MINI, being small will not fit through my door.... I spent a couple dollars on the MINI Fini grill.
Old Sep 17, 2011 | 06:59 PM
Clubman S Turbo's Avatar
Clubman S Turbo
I may try that too, coupled w/ the vented hood that should be fairly effective.
Old Sep 18, 2011 | 05:39 AM
-=gRaY rAvEn=-
Moderator
The grille is no wheres near thick as 1.5 inches...."Maybe" 5/8 of an inch at best.....This mod just performed on my friends 2011 Clubman.....Since neither of us had done this before, we got another grille from a melted bonnet scoop so he would have the original one just in case.
He did the work and it came out perfect.
Old Sep 19, 2011 | 10:34 AM
mslatter's Avatar
mslatter
It gives the turbo something to melt.
Old Sep 19, 2011 | 11:20 AM
Neitherfanboy's Avatar
Neitherfanboy
^^ Now that was funny right there!
Old Sep 20, 2011 | 10:50 PM
paul_voorn's Avatar
paul_voorn
Just FYI . Went in for my 3rd replacement hood scoop for warping probs. This time they added a heat deflector (under warranty)... Simple plate attached to the hood on the upper side of the scoop. Hood seemed cooler after a medium run. Only time will tell.
Old Sep 21, 2011 | 09:52 AM
christomapher's Avatar
christomapher
Has anyone bought one of those shields that blocks the turbo heat from melting the hood scoop? http://new.minimania.com/web/Item/G2.../InvDetail.cfm
Is it necessary or should I rely on my warranty to cover this if it ever happens?
Old Sep 21, 2011 | 02:04 PM
Clubman S Turbo
Paul, they did that to mine too, I got there with 49,967 miles and got a new scoop and S/S heat shield. The next ones on me, hopefully there wont be a next one. Tried to work w/ them to get a C/F or chrome one, they wouldnt budge. Some customer satisfaction quotient. :(
Old Sep 21, 2011 | 03:12 PM
DneprDave's Avatar
DneprDave
I see a lot more complaints about chrome scoops melting than any other styles here on this forum. could the metalic finish conduct the heat to the plastic underneath faster?
On my 2010 MINI, it looks like there's a heatshield already protecting the scoop, I bought it new and it just came that way.
Dave
OutMotoring
Mar 3, 2017 06:29 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
M7Speed
Oct 1, 2015 07:05 AM
mini merle
Sep 30, 2015 04:42 PM
drum6g
Sep 29, 2015 01:15 PM
