R56 Maintenance
Old Sep 1, 2011 | 07:03 PM
haristo's Avatar
haristo
Maintenance
Mr r56s being my first turbo car, i'm not that experienced with these kind of engines, would it be wise to change the spark plugs at 62000km?
Also, i noticed alot of black residue on my exchaust tips, alot more than other r56s i see on the road. I do drive it hard, i work on the road so i'm always pushing it.
What are some of the things i should do to keep the engine running at its best?
Old Sep 2, 2011 | 06:21 AM
schatzy62's Avatar
schatzy62
not required at such a low mileage.
this is very normal and the others probably just get cleaned more frequently than you clean yours.
read thru the modifications and stock problems/issues sections.
also do seafoam treatments on the car they are explained in both of those sections.
Old Sep 4, 2011 | 06:08 PM
rick92f's Avatar
rick92f
The factory plugs are ILZKBR7A-8G NGK Iridium plugs. They tend to last a really long time. If it worries you with that kind of mileage then pull them and take a look. Make sure that the head is cold before you take any plugs out. The factory installed gap is .031".
Keep up on oil+filter changes, take a look at your air filter, inspect the drive belt, and keep driving the snot out of your car.
Sep 10, 2019 09:22 PM
vulkandino
Oct 31, 2015 08:29 PM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
Sep 10, 2015 11:55 AM
ronn
Sep 9, 2015 07:12 PM
