R56 Manual transmission oil change guide
Old Jun 21, 2011 | 07:39 AM
JohnnyMCS's Avatar
JohnnyMCS
http://www.totehmoon.com/uploads/man...ission_diy.pdf
I found this online and thought I would share. It seems like the popular oils to swap out with are the Redline MTL (a little thicker viscosity than factory fill) and Redline D6 ATF (same viscosity as factory fill). Both are GL-4 compatible. (no sulfur to damage brass sychronizers)
Do not shoot the messenger...but here you go!
Old Jul 23, 2011 | 12:10 PM
hattenzoom's Avatar
hattenzoom
Going to do this...
Thanks for the info...
Old Jul 23, 2011 | 12:39 PM
slinger688's Avatar
slinger688
Just to add, if you have a factory LSD, then Redline recommends the Redline MTL fluid only.
Old Jul 24, 2011 | 01:31 AM
Porthos's Avatar
Porthos
It is always an option. I am going to wait till I am around 100k before I change mine.
Old Jul 24, 2011 | 04:35 AM
richardsperry's Avatar
richardsperry
That would probably only be 70K overdue...lol
Kimolaoha
Jul 5, 2023 01:04 PM
theblackfalcon
Oct 11, 2015 09:49 AM
panerai21
Aug 18, 2015 02:15 PM
ludedude
Aug 10, 2015 07:16 PM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
