R56 Will giving service advisor low rating have repercussions?
Old Apr 24, 2011 | 11:52 AM
  #26
90210oxygenblue's Avatar
90210oxygenblue
Originally Posted by DneprDave
At my local dealer, they don't assign a service advisor to you, you get the first one who is available. The ones I've dealt with are all very helpful.
Dave
Interesting.
BTW your avatar pic is my car
Old Apr 24, 2011 | 01:37 PM
  #27
dannyhavok's Avatar
dannyhavok
Dave
I believe my dealership generally works the same way, however I always call my "favorite" SA directly and try to book an appointment with her specifically. Now that we have built a working relationship I wouldn't mind giving some other folks a shot, but I like to build a relationship in scenarios like this. It makes it more pleasant to go in, and easier to smooth out any problems that come up.
Old Apr 24, 2011 | 02:12 PM
  #28
RJKimbell's Avatar
RJKimbell
Dave
Dave, if you're dealing with an SA @ Rasmussen you don't get "the first one who is available" at least if you don't want it that way, you can "request" which SA you wish to work with, just stating what I've been told.
Old Apr 24, 2011 | 03:22 PM
  #29
90210oxygenblue
Yup when I book an online appt, I can request the one I usually see. I prefer dealing with one, if I can.
Old Apr 24, 2011 | 10:27 PM
  #30
jaridp's Avatar
jaridp
If you have a preference you can request yes
Old Apr 24, 2011 | 10:50 PM
  #31
DneprDave's Avatar
DneprDave
Nah, They're all good.
Thanks!
Dave
Old Apr 25, 2011 | 03:50 AM
  #32
cristo's Avatar
cristo
Alliance Member
I'm thinking that not giving a low recommendation when it is warranted will have repercussions in the long run.
There will be no impetus to provide quality service.
Old Apr 25, 2011 | 06:10 AM
  #33
MCS Fever's Avatar
MCS Fever
Originally Posted by 90210oxygenblue
I recently went in for warranty repair. My repairs were less than well done, to say the least.
I got a customer satisfaction survey, and I want to detail the problem there.
Will writing it there, which will I assume get back to my service advisor, create problems later on?
I.e. you never want to say something to the waiter in hopes she doesn't spit on your food.
Thoughts?
For starters - what does the SA have to do with how well done the work was performed? Exactly what was supposed to be done, and what did not get done correctly?
At any rate - you should have no problem bringing up issues. When our '98 Dodge Caravan's waterpump went out in short order right after it was replaced, you can bet I brought that up. Result was no charge for the 2nd pump. And the lifetime oil change started at 20 mins to perform then got slower and slower to over an hour for a simple oil change even though you scheduled it. You can bet I talked to the service manager, although to no avail on the oil change marathon.
When GM canceled the order on my 2008 GMC due to "re-tooling for next year" after waiting over a month with $1,000 down, you bet I complained to GM directly. Result was 5 free lube, oil and filter changes on the rig I ended up buying off the lot, no cheap thing on a diesel that holds 10qrts of oil.
W0TM8
Dec 19, 2019 07:50 AM
JamJam43087
Aug 16, 2015 02:02 PM
Emnotek
Aug 13, 2015 05:47 PM
ludedude
Aug 10, 2015 07:16 PM
