R56 MOTOR swap
Old Feb 16, 2011 | 04:53 PM
5810's Avatar
5810
MOTOR swap
Hi, I have a mini with blown engine due to oil pump chain snapping 113k . Its a 07 mcs manual.
Im trying to find a wrecked one for reasonable price so i can swap engines, my question is, that there is alot more automatics than manual going for cheap.
Will a manual transmission bolt up to a auto motor.
Thanks.
sam.
Old Feb 17, 2011 | 01:17 PM
ptrd's Avatar
ptrd
I can't say for sure but generally, you normally can bolt up an auto motor (short block) to any transmission.
I doubt they have different blocks but the only way to verify is like online part numbers or the dealership.
Good luck.
Old Feb 17, 2011 | 01:24 PM
MINIdave's Avatar
MINIdave
You'll have to use your flywheel, and you'll probably need to install a new pilot bushing/bearing in the crankshaft. However, there may be other differences - oil cooler for the trans for instance - but if you're just buying a long block (block, head and internal components only) then the two things I mentioned should do it.
Good luck....and let us know what you find out, OK?
Old Feb 17, 2011 | 07:07 PM
5810's Avatar
5810
all i want from donor car is the engine(long block-complete) and ill part donor car.ill call dealer to verify.
Thanks for replies.
Old Feb 17, 2011 | 08:32 PM
5zero4's Avatar
5zero4
did you junk the block? it might be cheaper to get yours rebuilt if it it's not a total right off.
BRracing
Oct 24, 2015 10:07 PM
gmonde
Sep 28, 2015 05:22 PM
Mb460
Sep 14, 2015 05:50 AM
offroadratfabricator
Sep 6, 2015 09:54 AM
Manny_cooper
Sep 3, 2015 05:48 AM
