R56 In the mail today, Extended Warranty for HPFP
I'm sure a 2010 made in 2009 will be covered.
I recieved my letter today and I hope I never need to get it fixed. So far I have had no problems with anything at all in 14,000 plus miles.
I'm pretty sure you people that have 2010 models will be covered if you have a problem. They already know that there are some defective pumps but can't pinpoint just what cars have them.
My guess is that a few different suppliers manufacture that same part for them and they all look the exact same. The parts on demand in the factorys cause a few problems when something goes wrong.
At least BMW is better then GM was with the deadly column lock problems on the C5 Corvettes.
I have an sept 08 build 09, but still on my oem hpfp at 13k, will I still get a letter? nothing as of yesterday.
Now BMW needs to consider the same for those of us who've had to deal with the timing chain tensioner and valve train system.
No problems...although I probably just jinxed it by saying that!
I don't know the answer. If you are the original owner (I believe you are) and your mailing address has not changed, I would give it another week and see if your letter arrives. If you don't receive the letter, I would print out the letter at the beginning of this post and go see your service adviser. Ask them what the situation is. As long as your HPFP is ok, there is not any urgency, you just want the warranty situation resolved in the event of a problem.
this 2007 owner hasn't seen a letter
and wonders why this problem gets addressed
while the equally wide problem of the fan controller
on GEN1's fan assemblies gets nothing .... read around here
mine was replaced every 30,000 miles.....
where's our fix?
OR
what do we need to lift our problem to the alter?
where's our fix?
OR
I received the letter for both of my '07 MCS. Now if they would just do the same for the vacuum pump and timing chain systems ...
Do you get the feeling this engine was not ready for prime time?
Now, how did you manage to blow one up at 8500 miles in a car that doesn't even have one??? Or were you just carrying one around on the passenger's seat when it all happened?
It must have been the regular fuel pump, which is also a shame to fail, but at least it's unlikely that it will fail again and again every few thousand miles, like HPFP-s do...
Sorry, toolazyforalogin, but "justa" coopers DO NOT have HPFP-s, only turbocharged MCS-s do, hence it wouldn't make much sense to cover "justa"-s against this particular failure...
Thanks for the heads up.
This won't be much of a consolation to those of you who have had problems with their HPFP, but anecdotally, it seems to be a MUCH smaller problem on MINI's than on the BMW twin turbos (335, 135, etc.) VW and Audi 2.0T engines also have similar issues. My guess is they all use the same German supplier, possibly Bosch or the like, and there was either a questionable design, or bad batches of fuel pumps. I think the HPFPs tend to go hand in hand with the new generation of lowpressure turbo engines and hopefully we'll all survive the teething period. I have had two R56's with no problems, and do not know a single person in either of my local MINI clubs that have, so it's not like every one fails. YMMV. I do think MINI/BMW is being proactive offering the extension rather than either denying the problem exists, or dealing with each one on an individual basis.
HPFP failure early symptoms
According to my research, it rarely (I wish I could say never, but can't, sorry...) fails all of a sudden. Most of the time the first/early signs are hard cold (like in the morning, after sitting overnight) starts (not to be confused with the dreaded cold start death rattle - there is only an unusually long cranking time here) followed by not wanting to stay running and possible stalling. Sometimes it takes several attempts to start the car. While it's still cold, the car continues to sputter. Even warmed up it may no longer have full power available because of the decrease in fuel pressure, however under normal driving conditions you may not notice this at all, and the car may seem totally problem-free for the rest of the day (fuel pressure may be as low as 3MPa as opposed to the rated 5MPa). Problems may or may not trigger a check engine light.
Really? That's interesting. The way the letter is described, its for 07-09. This might give me some hope. I'll keep looking in the mail.
Are you saying that we have to get the letter for it to be covered? I have an 08 and Im not sure if I got it or not.
"The service engine soon" light? I think I get one of those, except currently, everytime I turn on the engine its says -1200 first.
If you are not the first owner, or have moved recently, etc. you may not receive the snail mail at all. It doesn't mean you are not covered. If you feel you can't wait another few days for the letter, you may call the number from the pdf posted on the first page of this thread and ask yourself.
The check engine light is not to be confused with the service reminder feature...
Regardless, asked my MA about this and I'm covered! It seems about all mini s's in that time frame is covered whether you got that notification or not. Hopefully, I wont need it.
I'm in Canada and I haven't gotten anything. Why's that? The US/CDN cars are the same. I hope I get something soon. I too wish they'd do something about the warranty for the 'death rattle' as well
